Bama performance
There are a ton of members on this forum using our Bama SF3 tuners. Try a few searches, I'm sure you'll find a lot of write-ups or reviews.
If you're looking for anything in particular to be answered, I can help you with that too. Let me know if you have any questions or if there's anything else I can do!
Shane
Shane
Have there been any innovations with the Bama tune profiles?
I have the "tunes for life" from you guys...I had a 91 octane perfomance tune for a while a year or so back but got nervous about the #8 poston failures so went back to stock.
It seems like the failures are a thing of the past...but is it worth getting an updated tune or will the early 2011 be the same?
Shane,
Should I load my early 2011 tune or get a fresh one?
I also bought the Boss quad exhaust from you guys...can you do anything with the slightly reduced backpressure?
Thanks! !
Help with tune
I had a question about the Bama tune.. I own a pypes axle-back muffler mod but on the custom tunes fill out form I selected the cat-back pypes exhausts mod . Would this require a retune?? Thanks
Typically the axel backs remove the resonator and have a little less back pressure. I would probably go ahead and get in touch with Bama and let them know you selected cat back and not axle back. If you have the free tunes for life program then you should be good to go and they will send you an updated tune.
