Sponsored by:
Sponsored by:
302 boss intake manifold
Old Apr 16, 2013 | 10:11 AM
yankee5.0's Avatar
Will that intake manifold fit perfectly a 2012 5.0
Old Apr 16, 2013 | 11:18 AM
ShaneGT's Avatar
it is a direct replacement. order the intake kit from AM, comes with everything.
Old Apr 16, 2013 | 11:48 AM
tj@steeda's Avatar
Requires custom calibration after installation.
Also requires additional parts available from your local Ford parts dealer for installation:
Ford Service Part # : CR3Z-9G297-A, Hose (1 pc.)
Ford Service Part # : CR3Z-9G290-B, Bracket (1 pc.)
Ford Service Part # : CR3Z-9J280-A, Fuel Lines (1 pc.)
Ford Service Part # : W506974-S437, Screw M6x16mm (1 pc.)
Ford Service Part # : CR3Z-9B659-B, Air Inlet Tube (1 pc.)
Yes it will fit perfectly ... but you will need to do some changes to make it work properly.
Here is a very good thread showcasing the install process:
http://www.mustangevolution.com/forum/f358/t286131/
Best Regards,
TJ
Old Apr 16, 2013 | 04:06 PM
GrabberBlue5.0's Avatar
You will also need to spin the motor to 7600+ to reap the benefits of it.
Old Apr 16, 2013 | 04:21 PM
steven46746's Avatar
Wouldn't suggest it, it looks nice but all it does is move your power band higher up in the revs and you lose a bit of torque.
Old Apr 16, 2013 | 05:07 PM
hwm3's Avatar
Easy install. You will have to get it tuned. You don't have to buy the parts from Ford, you can do it for about $6 in parts from your local Autozone.
As far as power and torque is concerned, with the proper tuning you will gain hp AND torque from 5000rpm and up. It keeps building power past 7500rpm too.
A little video of my car after the Boss intake install.
Old Apr 17, 2013 | 11:18 AM
conv_stang's Avatar
There's not much of an overall peak hp gain. The biggest benefit over a tuned 5.0 is spinning it past 7000. Where the factory manifold starts to drop off the Boss holds the power longer. At 7500+ there's 20+ hp difference between the two. If you don't or aren't willing to spin the engine that high it's mostly a cosmetic mod
Old Apr 17, 2013 | 02:25 PM
Yep most of gain is from the tune required to run the boss manifold, the coyote motor already has to be revved hard for power, the boss intake just makes this worse.
Old Apr 17, 2013 | 02:55 PM
flySWA737's Avatar
I just had a boss intake mani, steeda ProFlow, and tune along with my stainless works installed by Steeda and in my opinion it made a big difference. As you roll through 3500-4000 the car just pulls harder and harder the higher you wind it up. Also the power delivery is a lot smoother throughout. I can't thank Gus enough for the difference it made. I never felt a torque loss down low but I did go from a stock tune with cats to now catless with a tune.
Old Apr 17, 2013 | 06:00 PM
Burke985's Avatar
Totally worth it IMO , I love it car pulls to the moon
Old Apr 17, 2013 | 06:29 PM
Is the motor safe to rev that far in stock form?
Old Apr 17, 2013 | 07:54 PM
Burke985's Avatar
I wouldn't do it everyday but ive done it a bunch and have no issues. I think to see the most out of the Boss you have to have other supporting mods like headers , throttle body , gears and so on. Me and my brothers car are basically the same only he has 3.31 gears and after we installed his intake today I think my car feels stronger. He needs new tires and hes getting them this week soon as they go on we're lining them up and see whats up
Old Apr 19, 2013 | 08:27 AM
grabberblue 5.0's Avatar
"Moving the powerband" isn't necessarily true. While there is a shift, there is also quite a bit to be gained. Most people will agree that over 5k rpms the coyote screams and pulls like a freight train with the boss intake. The low end lost is pretty negligible with a steeper gear.
I have one and I love it and I would recommend it to most
Old Apr 19, 2013 | 11:25 AM
SteedaGus's Avatar
Glad you are enjoying it! Thank you for your business!
Old Apr 19, 2013 | 08:56 PM
Supra's Avatar
I just swapped a boss 302 intake onto mine this week. Love it so far. The power loss down low is very minimal in my opinion. Above 3000 rpm it pulls like a freight train up to 7500 and beyond. And it looks badass!
Old Apr 19, 2013 | 09:05 PM
dmhines's Avatar
THey do look good under the hood. Be nice if they made one that said Ford Racing or something instead of BOSS 302.
Old Apr 20, 2013 | 05:25 PM
typesredline's Avatar
I can tell you that despite what some say about the "loss" in tq being no big deal, it is. I will consistently run dead even with my buddy's 13 boss. And he is a better driver too.
Old Apr 22, 2013 | 11:49 PM
am5.oh's Avatar
It's awesome! If you get a good enough tune you won't lose any tq at all. I was at 397 380 w just intake and tune, after LTs and manifold I'm at 423 and "380" tq!!
Old Apr 23, 2013 | 02:54 PM
So you picked up 26 rwhp and 0 rwtq with the addition of longtubes and the Boss intake? That's really not impressive at all. Who's tune?
Old Apr 24, 2013 | 08:28 PM
conv_stang's Avatar
I took mine off, added an off road h-pipe and picked up 8 hp and 10 ft/lbs of torque over the Boss intake. I definitely miss the punch above the factory redline. But I found I really didn't wind it up that much. Gonna save the Boss intake for something different
