302 boss intake manifold
Will that intake manifold fit perfectly a 2012 5.0
it is a direct replacement. order the intake kit from AM, comes with everything.
Requires custom calibration after installation.
Also requires additional parts available from your local Ford parts dealer for installation: Ford Service Part # : CR3Z-9G297-A, Hose (1 pc.) Ford Service Part # : CR3Z-9G290-B, Bracket (1 pc.) Ford Service Part # : CR3Z-9J280-A, Fuel Lines (1 pc.) Ford Service Part # : W506974-S437, Screw M6x16mm (1 pc.) Ford Service Part # : CR3Z-9B659-B, Air Inlet Tube (1 pc.) Yes it will fit perfectly ... but you will need to do some changes to make it work properly. Here is a very good thread showcasing the install process: http://www.mustangevolution.com/forum/f358/t286131/ Best Regards, TJ |
You will also need to spin the motor to 7600+ to reap the benefits of it.
Wouldn't suggest it, it looks nice but all it does is move your power band higher up in the revs and you lose a bit of torque.
Easy install. You will have to get it tuned. You don't have to buy the parts from Ford, you can do it for about $6 in parts from your local Autozone.
As far as power and torque is concerned, with the proper tuning you will gain hp AND torque from 5000rpm and up. It keeps building power past 7500rpm too. A little video of my car after the Boss intake install. |
There's not much of an overall peak hp gain. The biggest benefit over a tuned 5.0 is spinning it past 7000. Where the factory manifold starts to drop off the Boss holds the power longer. At 7500+ there's 20+ hp difference between the two. If you don't or aren't willing to spin the engine that high it's mostly a cosmetic mod
Originally Posted by conv_stang
(Post 6605024)
I just had a boss intake mani, steeda ProFlow, and tune along with my stainless works installed by Steeda and in my opinion it made a big difference. As you roll through 3500-4000 the car just pulls harder and harder the higher you wind it up. Also the power delivery is a lot smoother throughout. I can't thank Gus enough for the difference it made. I never felt a torque loss down low but I did go from a stock tune with cats to now catless with a tune.
Totally worth it IMO , I love it car pulls to the moon
Is the motor safe to rev that far in stock form?
Originally Posted by steven46746
(Post 6605408)
"Moving the powerband" isn't necessarily true. While there is a shift, there is also quite a bit to be gained. Most people will agree that over 5k rpms the coyote screams and pulls like a freight train with the boss intake. The low end lost is pretty negligible with a steeper gear.
I have one and I love it and I would recommend it to most |
Originally Posted by flySWA737
(Post 6605252)
I just swapped a boss 302 intake onto mine this week. Love it so far. The power loss down low is very minimal in my opinion. Above 3000 rpm it pulls like a freight train up to 7500 and beyond. And it looks badass!
THey do look good under the hood. Be nice if they made one that said Ford Racing or something instead of BOSS 302.
I can tell you that despite what some say about the "loss" in tq being no big deal, it is. I will consistently run dead even with my buddy's 13 boss. And he is a better driver too.
It's awesome! If you get a good enough tune you won't lose any tq at all. I was at 397 380 w just intake and tune, after LTs and manifold I'm at 423 and "380" tq!!
Originally Posted by am5.oh
(Post 6609527)
Originally Posted by GrabberBlue5.0
(Post 6609946)
So you picked up 26 rwhp and 0 rwtq with the addition of longtubes and the Boss intake? That's really not impressive at all. Who's tune?
