Sponsored by:
Sponsored by:
3.73 Gear Install???
Old Feb 24, 2011 | 11:15 PM
DeathSpawn619's Avatar
So im about to order my Ford Racing 3.73 gears. So stupid question....What else do i need besides the gears? My car is a 2011 5.0 with an automatic transmission and only has 5,000 miles on it. So what would i need to buy besides the gears ? I have an SCT tuner already so do i still need the speed cal? And are Ford Racing gears the best to go with? Thanks for the help guys.
Old Feb 25, 2011 | 01:40 AM
Ducky's Avatar
Do you know how to properly lash the gears? If not, prepare for gear whine with possible grenading later on.
Old Feb 25, 2011 | 01:52 AM
Guest123's Avatar
That process can be easily learned! So I wouldn't worry about that.
Old Feb 25, 2011 | 05:24 AM
wproctor411's Avatar
I would take it to a shop unless you have experienced help....it would suck if your gears whined after installing them. My 4.10 and locker combo in my F150 is silent and I thank 4 Wheel Parts for that. They have service centers nation wide but other shops can do it. Ask around as I would not take it to a novice. I paid 375 for install plus price of parts. The FRPP gears are fine for most.
Old Feb 25, 2011 | 09:17 AM
CO_VaporGT_09's Avatar
I'd agree, and the dealer can do this as well (just more costly).
I figure, if you're asking what else you need, you probably need it installed.
If, however, you were already planning on that and are wondering about any ancillary parts your installer may need, here's a kit, though if the car is brand new you probably don't need any of it; sometimes the installers have preferences to replace certain pieces:
http://www.buyfordracing.com/shop/pr...=463cPath=3_37
Old Feb 25, 2011 | 11:36 AM
I'm defiantly taking it to a shop. Anyone know any reputable shops here in san Diego that I can trust on doing a good job? Once again thanks for the help
Old Feb 25, 2011 | 12:08 PM
Don't know why you have to be defiant about it...
But DEFINITELY ask some San Diego locals for advice, you don't want a gear install done poorly, for the reasons mentioned above.
Again, Ford dealers will do it perfectly (or should) but may be more costly than other places.
Old Feb 25, 2011 | 09:47 PM
Lol, I mean Definitely! Sorry **** auto correct on my phone. But yea, I will be taking them to a shop to install. I just ordered them. The gears, Royal purple gear oil, and 1 bottle of Ford Racing Performance Parts Friction Modifier.... I should be fine with just that right? I mean once i take it to a shop.
Old Feb 27, 2011 | 03:33 PM
Omcar's Avatar
The 2011s have a different bearing set than the other years.
Old Feb 27, 2011 | 04:49 PM
SteelTownStang's Avatar
Yes.
Old Feb 27, 2011 | 05:25 PM
ShaneGT's Avatar
subbing, i want to hear your results, as i have a Auto 5.0 too... something i want to do down the road..
Old Mar 3, 2011 | 05:01 PM
Double-EDad's Avatar
Whoa, that came out of left field! What is different about the 2011 bearings? I thought an 8.8 rear was an 8.8 rear.
Old Mar 8, 2011 | 08:51 PM
Turboba6's Avatar
WHOA HERE TOO...NEVER heard that...
Old Mar 9, 2011 | 07:36 AM
Not according to AM, they have the same ones listed as for the 05-10s.
http://www.americanmuscle.com/2010-mustang-gears.html
Old Aug 1, 2011 | 07:36 PM
BlackMamba03's Avatar
hey i know your original post is from march but i figured id put in my two cents worth. if youre gonna upgrade your gears, then youll need an install kit, a new traction-lok rebuild kit with carbon discs and a new 8.8 bearing. ford changed the bearing in mustangs in 2010+ so thats why theres a need for the new bearing. all of this is available at american muscles website. if you havent installed gears yet then good luck and hopefully this has helped.
Old Sep 20, 2011 | 12:35 PM
KONA BLUE's Avatar
I have a 2012 GT automatic. How'd you make out with the gears, what kind of RPM's do you turn at 60 in od. Thanks
Old Sep 20, 2011 | 12:43 PM
Are you planning on upgrading your stock gears? If so, to what? Remember, the higher gear you're using, the higher the RPM's will be on the highway.
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
GMAYS
Sep 10, 2015 06:19 AM
robjh22
Sep 8, 2015 12:31 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
