2011+ specific replacement struts/shocks???
For the few(or many) of us out there that do not want to or can not drop their ride on lowering springs, is there any word out there stating when aftermarket replacement dampers will be released for the 2011/2012 models?
As much as I want to, I can't put my ride on lowering springs due to my city road conditions. When they do I'll be ordering Steeda's HD Strut Mounts for the 2011+ Mustangs. Any ideas?
No 2011 specific struts on the horizon that I'm aware of. Nobody is all hot to trot to do it because it's so easy to just use the older strut mounts. In fact that's what Ford Racing tells you to do.
Thanks for the heads-up. After looking around, I see no one has any specific struts/shocks for the 2011+ 'stangs... only Tokico mentions on their website that they may develop something for the latest set-up. A little odd though that Steeda bothered to manufacture a heavy-duty strut mount for the 2011+ cars...
[QUOTE="mikeyt03;6709153"]So does eibach and koni. Im confused. There are a lot of 11-12 struts.[/QUOTE
The last posts were from 7/11. Since then, quite a few of 2011 plus specific shocks have been made.
Unless Steeda made a change, they were not offering Steeda HD struts designed specifically for 2011+... I know, because I ordered a kit.
My original plan was to upgrade the struts/shocks, add heavier duty strut mounts from Steeda, and leave the stock springs in place. As you can see from my signature below, that plan went right out the window!
Rando
Aug 25, 2021 11:12 AM
