2011 5.0 Strut Tower Brace
I don't do trannies
or rear-ends anymore!
I think this would look great under the hood, I'm guessing there is no way it will clear a factory 07 hood though. Is this a fair assumption or could I make it work?
I don't do trannies
I found this:
https://themustangsource.com/showthr...40#post5728140
So maybe KC can chime in on it?
*EDIT* I found this:
https://themustangsource.com/showpos...5&postcount=13
and this:
https://themustangsource.com/attachm...7&d=1199807341
I have lowering motor mounts, so now I'm curious exactly how much of a height difference there is. May be able to make it work!
and this:
I found this:
and this:
and this:
strut tower brace
My understanding is that ALL 6 and 8 converts. will have them . All G.T.s and V6's will have them regardless of option packages etc. AS LONG AS 19,s are put on the car.
If it was like for the 2010s, you get them with the 19" wheels to manage the extra mass and its effect on the handling set-up. The 18" wheels weight less than the 19s.
I don't do trannies
Engine height isn't the problem. Your strut towers are still in the same place and I don't believe your hood will accommodate. There's no way I'll be able to find the thread, but I remember when I was researching the 10+ strut tower brace someone with an 05-09 tried it and there wasn't enough hood clearance. Either way, KC should be able to confirm.
Maybe that helps but hopefully we can get a more definitive answer.
Received 1,538 Likes
SO, in case anyone wants to buy this, I found the part. It is the same part# for the GT coupe and convertibles.
Fender Reinforcing Bar
Part Number: 16A200
MSRP: $146.30
At my dealer: $117.04
Requires four HN3 M8 nuts @ $5.44 per
Part Number: 16A200
MSRP: $146.30
If you look at pics of the 2011 5.0 bar, it is much flatter than the 2010 bar so it may be that it won't clear the intake on a 4.6.
The Analog Admin!
Received 2,913 Likes
