4.6L GT Modifications Place to discuss the 4.6L 2010 motor based modifcations.
Coil Packs
Old May 29, 2010 | 08:25 AM
2010MustangGT's Avatar
Coil Packs
Are the coil packs worth the money?
I looked over this review: http://www.mustangandfords.com/techa...rade/dyno.html
And they got some serious gains- 20+ hp and 20+ ft lbs.
I read up on them and see these GMS have given a lot of trouble in the long run, but the MSD Blaster set seems to work very well. http://www.americanmuscle.com/msd-so...plug-0509.html
Anyone have any insight?!?
My next mod I'm thinkin these and a Steeda UDP set...
Old May 29, 2010 | 02:13 PM
Captain Spadaro's Avatar
What coil packs? The 4.6L 3V uses coil-on-plug igniyion.
Old May 29, 2010 | 03:13 PM
Right, the name for the product is called, "Coil-on-Plug Ignition Coil Packs"
I just called it Coil Packs for short...
check the article in original post and the picture timeline for what I'm talking about...
Old May 29, 2010 | 03:49 PM
GottaHaveIt's Avatar
Never get em wet either ! cost over 60.00 each x 8
Old Jun 1, 2010 | 07:07 PM
I just had an email exchange with Chandler over at Breenspeed. He says the MSD blaster set are a tested and tried coil pack, which is why they sell it,- and for a lightly modded car- such as mine, it will definitely increase the horsepower and torque.
Simply put: A Better Burn = More power.
They also don't require a new tune.
I think sometime this month I'll pick up a set...
we'll see.
Old Jun 1, 2010 | 09:15 PM
Ooh that's good to know any idea on a cost for a full set , I assume plug and play, if no tune required ? But if they increase the hpower ?
Old Jun 1, 2010 | 09:46 PM
Yup it's a direct bolt on. Yea I wondered on the retune as well... idk, I'll ask another breenspeeder just to be sure.
Here's a few offerings.
http://www.brenspeed.com/82438.html
Best price I found was: http://www.hdmaddog.com/MSD-46L-54L-...-p8404695.html
the cheapest site says 05-07, but it's the same MF number "82438"... Hence the same part- just not updated I'd assume. If you check the article link in the original post, it sees gains up to 27 hp 24 tq... granted those were for the GMS coils... but still, there's something to be had with the MSD's.
Old Jun 7, 2010 | 10:28 AM
Well, I emailed Dave over at Breenspeed as well as Dann over at American Muscle... Both had said that these offer little to no benefit to using them unless supercharged. While they offer a better burn and a hotter spark, they wont see much gains in NA form. Anything over 450RWHP Dave would recommend the swap, otherwise the stock setup are suitable
I probably wont end up getting these...
Old Jun 7, 2010 | 10:53 AM
Ltngdrvr's Avatar
That's exactly right, only real gain would be on a boosted motor where the increased cylinder pressure requires the much stronger spark.
If you use them on a N/A motor, it would help if you opened the plug gap some.
GeoWett
Sep 30, 2015 06:40 AM
UOP Shadow
Sep 27, 2015 07:24 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Fred_Garvin
Sep 17, 2015 04:10 PM
earl610
Sep 6, 2015 05:48 PM
