4.6L GT Modifications Place to discuss the 4.6L 2010 motor based modifcations.
2010 Mustang 4.6L GT Axle back rattle?*
Old Sep 2, 2011 | 02:56 PM
Exodus1021's Avatar
Put on a set of bassani's last earlier this week and have noticed a rattling noise every now an then. Everything seems firm and it only comes from passenger side. Anyone have an idea what it might be?
Old Sep 2, 2011 | 03:40 PM
Stangpilot007's Avatar
This is most definitely a hangar issue as I've seen it several times before.
Here's what you need to do. Lay under each of your Bassani mufflers and note the position of each hangar. The portion of the metal hangar that sits in the rubber isolator is not the issue. There's a few things to look for though. I know you say it's the passenger side but you definitely want to check each one just to be certain everything is okay on the other side too. They can shift over time and trust me I've seen it myself. When I changed exhaust setup's I was rattle free for three months before mine started rattling.
1.) On the passenger side muffler and the drive side muffler, check the vertical portion of the metal hangar furthest from the tips and check to see if it is resting up against the hangar bracket.
2.) Check each hangars near the tips. Note the hangar sitting in the isolator and then observe how far rearward the hangar is. My Pype Bomb's had a hangar by the tips which was touching the rear frame of the car (inside the rear bumper) and this created an annoying rattling sound on occasion.
What happens is the exhaust is rumbling and as it heats up and also cools when the engine is not running, the hangars can move +/- 1 inch or so forward and aft. This explains why you may not hear the rattling sound all the time, and it also means that when you lay under your car and check the hangars they may not be touching, but you will likely find that it will be very close. When the metal hangar comes in contact it resonates up into the rear of the car creating a very fast but intermittent metal on metal contact which creates this rattling sound that you hear from time to time.
Here's a couple picture's I edited of the Bassani axleback's to show you the specific locations to check.
Once you check it out and assess which hangar it is I can help you with a solution.
Old Sep 2, 2011 | 07:08 PM
Exodus1021's Avatar
(jaw dropped) thanks!
Old Sep 2, 2011 | 07:09 PM
Exodus1021's Avatar
I'll do it tomorrow at work, thanks a million for all of that!
Old Sep 3, 2011 | 10:06 AM
Kona Blur's Avatar
I had the same issue when I first switched mine out... Super informative reply exodus! Wish I had that when I was fixing mine...
Old Sep 3, 2011 | 11:08 AM
Exodus1021's Avatar
Well I got a chance to check it out and it seems I had a loose upper bolt on the rear passenger side hanger. The washer was the one making the noise. I checked all the hangers anyway and they all seem good to go! Thanks again for all the information and hopefully someone else can use it for further reference! Again thanks!
Old Sep 3, 2011 | 11:10 AM
Good to hear it's resolved anyway. Now you can really enjoy your Bassani's.
Old Sep 3, 2011 | 11:38 AM
Exodus1021's Avatar
Oh yeah!, I also got my calipers painted today as well!
Old Sep 3, 2011 | 07:23 PM
Kona Blur's Avatar
<img src="https://themustangsource.com/attachment.php?attachmentid=92645"/>
<img src="https://themustangsource.com/attachment.php?attachmentid=92646"/>
Calipers look great!
Old Sep 3, 2011 | 07:37 PM
Exodus1021's Avatar
Novelty goat
12
Sep 21, 2009 09:26 PM
muslenutz
Jul 4, 2007 11:05 AM
Tampa07GTCS
Jun 12, 2007 12:37 AM
monster693
Apr 17, 2007 10:34 PM
120rir
V6 Performance Mods
Jun 14, 2005 04:22 PM
