Black Black 2010+ Mustangs
BackinBlack13's 5.0 Build journal
Old Nov 1, 2012 | 10:52 PM
  #61
BackinBlack13's Avatar
Just a sub. But if you pull up that gray mat..there is absolutely nothing in the wheel well and all around the trunk. It should tighten things up with rattles. I hope.
Old Nov 1, 2012 | 11:01 PM
  #62
SilverSkoundrel's Avatar
which brand ya going with?
Old Nov 2, 2012 | 07:18 AM
  #63
Not sure yet, nothing expensive.
Old Nov 2, 2012 | 07:25 AM
  #64
Wax job last weekend.
Old Nov 2, 2012 | 07:28 AM
  #65
06blackvertstang's Avatar
Wow very nice. Excited to see how the trunk project turns out as well
Old Nov 2, 2012 | 11:44 AM
  #66
MyStang2010GB's Avatar
Brembo wheels/pirelli summer tires sold!! Got a **** good amount. I'm shocked.
How much? I'm about to list mine.
Old Nov 2, 2012 | 11:49 AM
  #67
PM sent.
Old Nov 2, 2012 | 12:38 PM
  #68
PM sent.
thanks
Old Nov 4, 2012 | 02:03 PM
  #69
Picked up these hood struts from member Lewis26. I've been lazy and haven't installed them yet.
Old Nov 4, 2012 | 05:08 PM
  #70
Pilks's Avatar
Pulled center console, removed boot. Boss ****/GT500 alcantra boot.
Where did you get this? Did you purchase this package somewhere?
Id like to do something just like this in my 13 GT
Your set up looks great and the car looks fantastic
Old Nov 4, 2012 | 06:50 PM
  #71
Thanks dude. Go to partscheap.com...mustang interior. Both should total around 85.00.
Old Nov 4, 2012 | 07:26 PM
  #72
Pilks's Avatar
Thanks, its going on the Christmas List! Was this a simple install?
Old Nov 4, 2012 | 07:33 PM
  #73
Easy. Pop up the center console. The only hard part was taking off the boot bezel. Broke one tab but it doesn't show.
Old Nov 5, 2012 | 04:34 AM
  #74
Pilks's Avatar
This installation (from partscheap) had me worried id be chopping up something brand new...
2010-2012 Mustang GT500 Alcantra Shift Boot
Part Number: AR3Z-7277-AA
"Installation: In order to make this work on a V6 or GT Mustang, some modification is required.
The diameter of the boot collar is slightly smaller than the stock boot, you will need to use a dremel tool, or a small knife to shave away a small amount of excess plastic. There is also a plastic spike coming down from the bottom of the collar. This can be cut and shaved away for flush fitment."
Old Nov 5, 2012 | 07:09 AM
  #75
Don't worry there are about 9 tabs. If you break one or use a dremel to cut one off, it will not affect the boot.
Old Nov 8, 2012 | 09:40 AM
  #76
Dynamat superlite ordered! (6 sheets)
Old Nov 20, 2012 | 01:55 PM
  #77
Dynamat came in. Hope to start this weekend. I may need another box. 39.00 per box at onlinecarstereo.com
Old Nov 20, 2012 | 02:17 PM
  #78
Not bad! Excited to see how it turns out
Old Nov 24, 2012 | 06:39 PM
  #79
I used up every bit of the 2 boxes. There is some scraps left I'll use for any spots I missed. I would like to get 1 more box later to do the panel under where the rear speakers sit.
Attached Thumbnails BackinBlack13's 5.0 Build journal-photo-33-crop2.jpg   BackinBlack13's 5.0 Build journal-photo-30.jpg   BackinBlack13's 5.0 Build journal-photo-32-crop.jpg   BackinBlack13's 5.0 Build journal-photo-35-crop.jpg
Old Dec 9, 2012 | 08:35 PM
  #80
SeanD's Avatar
Any huge difference in the inside cabin noise levels after you put in that Dynamat?
