Notices
Is my Clutch Toast???
Old 6/4/10, 03:14 PM
bpmurr's Avatar
My car is not holding the power while its in gear. If I have the car say in 4th gear at 2k, step on it, the tach will raise crazy fast. Then the car will catch, tach drops, and I smell clutch. Is this a sign that my clutch is toast or something else?
Old 6/4/10, 03:33 PM
xlover's Avatar
wow that sounds bad, and sounds like the clutch.....
Old 6/4/10, 03:44 PM
PTRocks's Avatar
Yep, it's clutch. Park it and take it to the dealer asap.
Old 6/4/10, 03:48 PM
yeahyouknwit's Avatar
Man that sucks. Sure does sound like the clutch
Old 6/4/10, 04:04 PM
Boomer's Avatar
Beating the **** outta your clutch lately?
Old 6/4/10, 04:35 PM
bpmurr's Avatar
Nope, which is why I'm surprised. The car has 9,600 miles on it. A poster on another forum says it just might be glazed and I should just drive normally and do lots of gear changes.
Old 6/4/10, 04:44 PM
MOTM Committee Member
stangfoeva's Avatar
could it be the extra power yours puts out now cuz of the mods?
Old 6/4/10, 04:45 PM
PTRocks's Avatar
I would only consider doing that if the car was out of warranty.
Old 6/4/10, 04:46 PM
Man that really sucks to hear.
Old 6/4/10, 05:04 PM
bpmurr's Avatar
You would think it could handle just a pulley swap. They put beefy clutches in these cars or do they.....
Old 6/4/10, 05:06 PM
fdjizm's Avatar
I stick to my original reccomendation, if that doesn't work, dealership time.
ford oem clutches hold ALOT for being oem.
Old 6/4/10, 05:12 PM
stangfoeva's Avatar
Thats true. I guess in this situation I'd take it in and let the dealer fix it
Old 6/4/10, 06:05 PM
Boomer's Avatar
Could be..I've had what I thought was a clutch going, and found it went away. (glazed slightly)
The slip was VERY minimal though, but you have a lot more power than my lowly 3v.
(mine was from stop/go traffic)
Old 6/4/10, 06:20 PM
1 COBRA's Avatar
It should not be an issue but the dealer might try to make one out of it.
Old 6/4/10, 06:22 PM
stangfoeva's Avatar
good point. bpmurr, perhaps you should switch back to the stock tune before you take it in...
Old 6/4/10, 06:44 PM
1 COBRA's Avatar
... They put beefy clutches in these cars or do they...
For normal driving, yes.
As an example of Ford's approach look back at the '07s' heat -warped flywheels-grinding shifts problem. Just because the GT500 is their starship Mustang it doesn't mean they don't count the beans whether for the '07s, the '10s, or the '11s for that matter.
Old 6/4/10, 08:04 PM
bpmurr's Avatar
Can't, it's got a the pulley on it. Plus the dealer already knows and is cool about it. (at least is at the moment)
Old 6/4/10, 08:28 PM
stangfoeva's Avatar
Dang, well good luck man. Hopefully they still honor the warranty
Old 6/9/10, 01:30 AM
Ice Hawk's Avatar
Wow. I don't have but 1100 miles on mine but now I'm worried about it. I was under the (potentially false) impression that these new clutches were really good and can take a beating with some real power. I hope that is still the case.
Old 6/9/10, 02:52 AM
CooBra07's Avatar
Keep us posted!!
Quick Reply: Is my Clutch Toast???
