Blue replacement filter for those running a FRPP 750hp Whipple kit
Old Mar 3, 2012 | 12:42 PM
1 Alibi 2's Avatar
Never liked the red air filter that came with the kit, looked all over for a blue filter with the same dimensions, that didn't have a blanked off end. Finally found one @ AFE.
The filter specs are listed below. This is for the FRPP 750 hp Whipple kit.
.( for a 123 mm MAF housing )
6" flange bore
1" flange heigth
7.5" base dia.
8" element height
5.5" top dia............( top is not blanked off )
As the filter I have is a " custom " ( prototype ), I am not sure of the pricing. The part # on the invoice, ( 24-99999 ), does not come up on the AFE website search. If you are interested, please use the contact information below:
Steven Baker
Direct Sales
advanced FLOW engineering, inc.
252 Granite Street
Corona, CA 92879
Company: 951-493-7100
Direct line: 951-493-7134
Fax: 951-734-1249
Email: sbaker@afepower.com
Web: <http://www.afepower.com/
.......................Before
.......................After
Old Mar 3, 2012 | 12:51 PM
dmhines's Avatar
You know the blue is just dye in the oil. I bought a JLT CAI and it came with Red filter. I bought a $10 AFE re-oil kit with blue oil. I washed out the red oil and re-oiled with blue to change the color.
Old Mar 3, 2012 | 12:53 PM
11SHELBYGT500's Avatar
You can buy blue oil from summit.
Old Mar 3, 2012 | 01:00 PM
1 Alibi 2's Avatar
Good fix & I knew about the dye in the oil.
Do you have a pic of your " after " color change filter, would like to see how it turned out ?
Old Mar 3, 2012 | 01:06 PM
dmhines's Avatar
Haven't installed in car yet ... stilling breaking in the new 5.0 before I load a tune and lose my Warranty.
Old Mar 4, 2012 | 05:53 AM
1 Alibi 2's Avatar
That came out good, what did you use to remove the red oil ?
Old Mar 4, 2012 | 09:13 AM
dmhines's Avatar
The recharge kit comes with a bottle of cleaner and can of oil.
Old Mar 5, 2012 | 11:23 AM
Ninjak's Avatar
Can you do that will the Yellow stock one ?
Old Mar 6, 2012 | 02:59 AM
1 Alibi 2's Avatar
I wouldn't call the stock one paper, but to my knowledge, it's a throw-away, not intended to be cleaned. There are several mfgs. that make blue & or red replacement filters that fit the " stock " CAI.
Noticed in your sig that you're running 1 7/8" longtubes, might you have a dyno sheet showing your torque curve after the install ??
When I did my headers, SVT, Kooks, & my tuner all recommended 1 3/4" instead of 1 7/8".. ( & there was no cost difference )
Rodsmustang
Sep 16, 2015 04:02 PM
jonser
Ecoboost
Aug 30, 2015 11:47 AM
Mackitude
Aug 13, 2015 01:05 PM
chadh92
Jul 29, 2015 06:56 AM
