Mustang AUDIO performance thread
Old Jul 26, 2007 | 10:17 PM
  #121
Shelby10''s Avatar
Actually capacitors keep your headlights from dimming when running bass... those are the ignition coil looking things in the trunk of bass heads cars... so you made a good suggestion
Old Jul 27, 2007 | 09:53 AM
  #122
cobra4548's Avatar
Jarrod can you send me the step by step install you got PM'd on modularfords?
Old Jul 27, 2007 | 10:09 AM
  #123
Shelby10''s Avatar
i never got those instructions... The PMs I got wreent descriptive so we didnt use them
Old Jul 27, 2007 | 12:52 PM
  #124
cobra4548's Avatar
Well, do you have anything for me that can help me hook up an amp?
Old Jul 27, 2007 | 01:03 PM
  #125
Shelby10''s Avatar
The instructions that come with the Amp were VERY helpful... had pictures to follow and walked you through the install. I believe all Amps come with install instructions nowadays. I personally dont have anything that would help you with a 4 or 6 channel. I mean you have your power wire to connect to the battery. Your REMOTE wire that connects to an open fuse behind the passenger fuse panely plate in the cab, the then you have your Output and input to hook up. Its not terribly confusing, I would take a look at the AMP instructions when you get it.
Old Jul 27, 2007 | 02:41 PM
  #126
n8rfastback's Avatar
i would connect the remote wire from the amp to the power antenna wire on the head unit. that way the amp wont come on unless the hu does.
thats the best way to do it, and you can hook it up when you hook up your RCA's
the amp directions will tell you how to hook everything else up
Old Jul 27, 2007 | 03:04 PM
  #127
Shelby10''s Avatar
hmm thats a good Idea. They way we connected mine I guess that the Amp is on when the car is on even if the head unit is turned off. I have the factory head unit in mine.
Old Jul 27, 2007 | 08:54 PM
  #128
cobra4548's Avatar
I think I am just going to go with a little 4 channel amp to boost the front and rear speakers for now. If I want real bass I'll add one in the trunk like Jarrod did. I guess I'll order this next month and install it then since it doesn't sound too hard. I figure if Jarrod can do it, then any retard can...:-)
Old Jul 28, 2007 | 09:03 PM
  #129
car audio is easy!!!! and fun once you know what your doing
the other thing i do is put a 12v switch on my amp turn on wire, that way you can kill the amp and subs any time you want.
Old Jul 28, 2007 | 11:45 PM
  #130
snakbytn2006's Avatar
Just FYI - if you want to re-do the front speakers, it's not as simple as buying a '4 or 6' channel amp. The car is not wired like that.
If you want to upgrade the system, in addition to just adding good sub-bass to round it out (a 10 or 12, or pair of 10's or 12's in the trunk), then you'll have to re-do the whole system, from head unit to speakers to amps.
My suggestion: Start out with the 500, and just tap into it to add a sub-amp and 2 subs to the rear. The mids/highs are plenty good in this system. Only a true audiophile will need more mid/high than what the 500 puts out. And if you try to add more, you're going to be in a world of hurt (money) to get it to work otherwise.
Old Jul 28, 2007 | 11:49 PM
  #131
Shelby10''s Avatar
Thats why when I think of spending money on my car I just break a fifty into 1's and head to nighttrips... cheaper in the long run They have music there and good bass
Old Jul 29, 2007 | 11:51 AM
  #132
cobra4548's Avatar
None of your suggestions are doable Jeremy for me. I have an aftermarket HU and so I have the pre-amps so hooking up an amp is a sinch. It's the subs in the doors that are a problem. I am going to get a 5 channel amp that will use the 4 channels for the speakers and then use the 5th channel for a sub in the trunk some day.
Old Jul 29, 2007 | 02:36 PM
  #133
Shelby10''s Avatar
Will that 5th channel support a sub??
Old Jul 29, 2007 | 02:46 PM
  #134
cobra4548's Avatar
Yes, according to the manual it will support a sub no problem.
Old Jul 29, 2007 | 05:25 PM
  #135
Shelby10''s Avatar
Hey jeff if you spring for digital you have all the channels you need including movie channels
Old Jul 29, 2007 | 06:12 PM
  #136
cobra4548's Avatar
Huh? Are you talking about cable?
Old Jul 29, 2007 | 06:25 PM
  #137
DavidM's Avatar
satellite! Go digital!
Old Jul 29, 2007 | 06:38 PM
  #138
cobra4548's Avatar
I do have satellite radio:-)
Old Jul 29, 2007 | 07:17 PM
  #139
your gonna have to buy one heck of a 5 channel amp to run 4 doors and 1 sub. the doors are not the problem, getting a big enough amp to drive a sub on the fifth channel is gonna cost ya
Old Jul 29, 2007 | 07:32 PM
  #140
cobra4548's Avatar
It's a 900 watt Earthquake 5 channel amp. At 2-ohm 4X240 and 1X500; 4-ohm 4X130 and 1X400. This should work right? I used to compete in IASCA and I always used Earthquake amps and they are awesome.
