Lowering car
Old Jun 6, 2007 | 07:46 PM
osudoc21's Avatar
Lowering car
This is a question for those of you who have lowered your car. I have the Eibach prokit on order, what else to i need to replace? I have been reading up on the mustang suspension on the forum and still have not formulated a list of other things i should be changing out, if any. I see most of you have used lowering springs on your stangs. so if you could just help me out here, remember i am a newbie still!
Old Jun 6, 2007 | 07:52 PM
cobra4548's Avatar
For just lowering the car you really don't need anything else. It depends on what you want to do with the car (drags, overall driving, etc) as to which suspension parts you replace.
Old Jun 6, 2007 | 07:54 PM
2006GT's Avatar
No prob... The springs are really all you need. You might have a little bit (1-2 degrees) of neg camber but it's really no biggie. It actually makes your car handle better, but will wear the inside of your tires a little quicker.
Ford has cam bolts to correct the angle if need be. I kinda like the handling plus... I can show you in person on Sat.
Old Jun 6, 2007 | 07:59 PM
2006GT's Avatar
Doc.... good article. Explains a lot... not all... but a lot.
http://www.tirerack.com/tires/tirete...e.jsp?techid=4
Old Jun 6, 2007 | 08:11 PM
DavidM's Avatar
I don't have any experience with the Eibach other than the three other guys that have them here in the club. Seems to be a pretty strait forward affair. I chose the Steeda Ultra lite springs which don't give quite as much drop as the Eibachs. I will be installing on Sat so you can get a first hand view of what is involved.
Old Jun 6, 2007 | 08:15 PM
07 HOSS Mustang's Avatar
If you want a decent ride you need to get some Tokicos, preferably the D-Spec adjustables ($360 or so for struts and shocks w/ forum discount at www.stangsuspension.com)NO SHIPPING
Old Jun 6, 2007 | 08:19 PM
2006GT's Avatar
wow... 350 hogs. Not bad.
Old Jun 6, 2007 | 08:27 PM
DavidM's Avatar
350 Jeffs? How is that possible I didn't think swine could reproduce like that. LOL Jeff you are still a swine. Until you give me a ride in that beast anyway.
Old Jun 6, 2007 | 08:30 PM
2006GT's Avatar
Ouch ! ZING!
Old Jun 6, 2007 | 08:37 PM
DavidM's Avatar
I figure after all the secrecy a little ribbing is in order.
Old Jun 6, 2007 | 08:45 PM
osudoc21's Avatar
thanks for the help!
Old Jun 6, 2007 | 08:54 PM
DavidM's Avatar
Welcome! Again Sat there will be springs being installed so this may help in your decisions.
Old Jun 6, 2007 | 09:03 PM
Shelby10''s Avatar
Jeff is right... first you must determine what you want to do with your ride. if you like any type of racing I would definitely look into the tokicos shocks, they are sweet, they allow you to adjust your ride to your likeing. you can make your ride stiff as hell for the track or soft as hell for grandpa soft road trips, brings your ride back to better than stock. now for traction purposes Lower control arms and relocation brackets are a plus. When lowering the car you also move the angle of the factory LCAs which change gripping power at the drag strip. Paul is right about neg camber and the bolts can fix that. Also some times after lowering the rear end kicks to one side, an adjustable panhard bar can fix that lickity split!! Also the final thing would be to adjust the cars center with an Upper control arm. But for just everyday driving, lowering springs are all you need
Old Jun 7, 2007 | 06:29 AM
I was told you will need the camber bolts. I will be doing the pro springs soon also.
Old Jun 7, 2007 | 10:25 AM
osudoc21's Avatar
the tokicos are not close to 360! try 500 after discount at stang suspension. also i couldn't find the camber bolts very easy.
Old Jun 7, 2007 | 11:04 AM
Shelby10''s Avatar
Hey Doc I graduated from OSU in 06'. Glad to see there is another die hard OSU fan in the mix.
Old Jun 7, 2007 | 12:01 PM
osudoc21's Avatar
cool, i just ordered OSU embroidered orange and black leather seats, should be in next week!
I did find the camber bolts at the partsbin.com
Old Jun 7, 2007 | 06:15 PM
I thought napa had the camber bolts for cheap
Old Jun 7, 2007 | 06:40 PM
camber bolts at www.IAPdirect.com
Mine were $27.90 ...shipped ....work well
correction on the Tokicos.. about $520 w/ Mustang Forums discount(5%)free ship!!!! $30 more get rears remote adjusters!!!!!!!!!!
jc46002003
Apr 15, 2016 03:00 PM
SMBJoshy
Aug 24, 2015 10:55 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
