window frame
Old Nov 11, 2013 | 09:41 AM
I-70 west's Avatar
window frame
how does the black plastic window frame come off ?
On the drivers side I`ve got a leak when I park up hill and I see something in between it and the body of the car.
Old Nov 12, 2013 | 06:32 AM
AzPete's Avatar
My 07 had that same issue. Ford had to pull the trim and replace that foam sealant. Not sure how to pull the trim section. Mine never leaked there though.
Old Nov 13, 2013 | 03:29 PM
roger blose's Avatar
window frame fix
This is a simple fix...just carefully pull off or down the rubber window gasket attached to the roof and you will see several screws that hold the black window trim in place. Pull the trim back and reseal the area with foam and silicone sealer and reassemble. I fixed my dreaded water leak this way as the water was running down into the passenger floor following the A pillar. There is a TSB on this as well if you get stuck.
Uofmrampage
Aug 2, 2022 02:55 PM
iliveonnitro
Oct 7, 2021 06:31 PM
kponypower
Jun 17, 2020 07:17 AM
CoyotePremium13
Sep 23, 2015 06:45 PM
5.M0NSTER
Sep 16, 2015 08:00 AM
