when should i get a tune-up?
Old Nov 24, 2011 | 09:56 AM
omgunclewong's Avatar
I got a used 05 stang at 65k miles and I'm at about 71k now. Wondering when I should get a tune up and how much am I expecting to pay for it. Just trying to stay up with all the things to keep the car heatlthy not sure what the previous owners have done.
Old Nov 25, 2011 | 03:22 PM
KdF's Avatar
KdF
Doing it yourself or not?
Not really much to do on a Car with injectors except change the plugs, gap them correctly and change fluids.
Seafoam is good to clean the Injectors.
Clean the Throttle-body.
Wash the engine bay.
Check the serpentine belt for wear.
What esle?
Old Nov 25, 2011 | 03:49 PM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Good luck with the plugs... Unless we are talking v6
Old Nov 25, 2011 | 04:46 PM
11SHELBYGT500's Avatar
Today's vehicles don't require a tune up in the classic sense. You should have changed the plugs as soon as you took ownership. I agree with everything that kdf said except I would never clean a throttle body.
Old Nov 25, 2011 | 08:22 PM
Thanks everyone for the info. I'm considering to do it myself if I'm just changing spark plugs and andb cleaning my fuel injectors. I just got some techron. And yes I have the stock v6
Old Nov 26, 2011 | 02:11 PM
DaTT(1sK)'s Avatar
Why would you not clean the carbon out of the throttle body?
Old Nov 26, 2011 | 02:14 PM
Right. A dirty throttle body is a frequent source of problems - several threads about it.
Old Nov 26, 2011 | 03:56 PM
JimC's Avatar
legacy Tms Member
You should change the fuel filter too at this point. Easy to do, you will need to jack up the driver side of the car (use jack stands to hold it!) - pull the pins holding the plastic panel on the bottom and the filter is under the driver seat.
Pull the fuel pump fuse under the hood and let the car run and die to relieve the pressure - use the tool if needed to release the filter (you may have green tabs that you push instead to release), unbolt the mount so you can slide the filter out, slide the new one it and button everything up. Put the fuel pump fuse back in, turn the ignition to "on" and let the fuel pump run to pressurize your system and start the car.
Scott Roberts
Sep 24, 2014 04:29 PM
Hoopcrazytr
Mar 31, 2013 06:53 PM
99ponygt
1994-2004 V-8
Aug 27, 2012 12:33 PM
David96GT
1994-2004 V-8
Dec 3, 2011 07:59 PM
