water leak on pass.floor on 05 gt vert.
![Angry](https://themustangsource.com/forums/images/icons/icon8.gif)
Is there any new info on this subject? was reading old post.didn't see anything new. unless i missed it.Is there a tsb on this yet? I have had car for 3yrs and this just happened.also any ideas how to fix?.... thanks
check this tsb , its the seventh one down. Not sure if this is new info to you, good luck
http://www.dr-mustang.com/index.php?...wtopic&t=40961
Funny , I just posted abut this in another thread about work done after the warranty expires. I discovered mine after the car was out of warranty and so far they've tried two times and it's cost me $876 and it's still not fixed , so if you're still under warranty get it to the dealer quick. It's not leaking as badly as it was so they did fix something , maybe you'll have better luck than I've had so far ...
I have this problem in heavy rain, i'm still under warranty, running to the dealer!!!
I found a puddle on the floor in front of my rear passenger seat, 2 days after it stopped raining.
I JUST fixed this issue on my neighbor's 2008 V6... His passenger side was getting water... traced it to the vent fan box... Long story short... The drain port on the passenger side under the cowl was clogged, so the water backed up and came through the cabin filter.... Pop off the passenger side cowl, and look towards the center of the car. there's a black grommet. His had 4 inches of water in there. Got the shop vac in to the grommet. It sucked out the leaves and grime and now all is well.
i havent check this post in a while i guess i should have but anyway.I recently found a different way how to unclog my cowl full of water. i found two black groments on the fire wall one on the pass. side and the driver side.i unplugged them and water came gussing out.the groments were both clogged.cleaned them out and blew out cowl
