Are TSB fixes done free of charge after warranty expires?
P.S. wish there was a separate warranty thread. Oh, the good old days...
Sometimes the TSB's don't last for the entire warranty period
I had my car in for the squeeking rear brake TSB, but the dealer could not do the service because it can only be done a maximum of one year after the date of purchase or start of warranty. In any case, i'll be upgrading to Hawk pads in the new year anyways
The Analog Admin!
Received 3,157 Likes
no!<<<<<
Depends, once your warranty ends you are basically only allowed two "out of warranty allocations". From what I can remember our service manager said there is a time frame to use them (maybe a year). Most Ford service centers won't tell you this info. Plus, you generally have to help pay for at least half of the cost. So, the question is... Is the TSB you are worried about worth using up one of your allocations? If the issue is less than $300 just pay for it yourself. Cos, if your engine or tranny ever die on you and it's a warranty issue it's better to have your allocation available.
I owned 1999 Pontiac Grand Am. 100 miles after the warranty expired everything went wrong. Thrown lifter rod, cracked engine block, broken motor mounts, and almost every sensor died. all within a week. It took a few months and countless letters and phonecalls to GM to get them to pay for it all. Moral of the story is. The extended warranty is worth it just to avoid the hassle.
If you took it in for an issue before the warranty expired, and they didn't catch it.... as long as it's on record with them, and at the final resolution, it should have been covered by the warranty... I'd be all over the a** of the service manager like stink on diaper.
I have an early '05 that the horn button pitted and was replaced under the 36,000 initial warranty. About 3-4 months after the replacement, the horn button pitted again! This was last summer. I figured that if the replacement pitted, then Ford hasn't fixed the problem. So I just now took it back in for some maintenance and had them check the horn button. They agreed it is pitted, but it is not covered under my Extended Service Plan because they consider that to be "cosmetic" - eventhough if there is condensation causing the pitting, then that condensation could also cause the wiring and other electrical components to short out resuling in horn and airbag failure, etc. Ford claims to not know anything about the pitting problem. Can we say "buried their heads in the sand"?
I would think that if the replacement part was defective, that they should replace the replacement part but apparently not - and I talked to Ford in addition to the dealer. No luck.
In that case they wouldn't issue a TSB, they would issue a straight Safety Recall. Nobody does a recall unless it is safety related. Issues that are just a known problem, not safety related get a TSB. Safety issues get a recall and those are immune to warranty date/mileage.
a TSB is a technical service bulletin nothing more , it is a notice to service departments listing common concerns and problems and the proper repairs that are advised to repair them . So if your vehicle is under warranty and is having the listed problem , then yes its covered , if your out of warranty it dosent offer any extentions or additional coverages .
Rando
8/25/21 11:12 AM
