Temperature gauge problem
The temp. gauge on my car does not go down to 0 (far left) when the car is turned off. It was stopping at about the 1/4 mark and this morning it started at about the 1/2 mark and when warm was way past the redline on the right. Not sure if the gauge has gone bad or what.
I see yours is an 05 and a lot of us have had the instrument cluster go bad and some of the gauges give false readings. Sounds like you've got one ...
Each gauge has a stepper motor on the back of it that runs it. Go on Ebay and type this in, and you will find several vendors selling an updated version of this motor. Most are about eight bucks each plus some shipping. Order enough to do your WHOLE cluster. (Either four or six, depending on the option on your car.) The cluster has to come out; five minute job at the most. Take the lens off and take it apart. If you're good with a soldering gun, you can fix this yourself. I'm not, so I had a friend do it for me on my tachometer. That's why I say order enough motors to do them all. As soon as my tach was fixed, the temp gauge crapped out, and started acting exactly like yours. Fix them all at once; they're all going to go out anyway. It was my way of not having to buy a $400.00 cluster from Ford, and have it programmed.
Here's a link showing how to do the stepper motor replacement:
http://www.ratstangrestoration.com/S...ent%20Pack.htm
And here is a link to buy the stepper motors:
http://www.ebay.com/itm/New-Gen-4-X2..._Video&vxp=mtr
I'm looking into this now because the oil pressure gauge on my '05 GT started pointing to somehwere between 11 and 1 o'clock instead of the normal 5 to 7 o'clock positions. This just started happening yesterday on mine.
I got the instrument cluster out and the motors replaced but when I put it back in and hook it up the needles do not move when I turn the car on. Not sure what the problem may be. the rest of the dash appears to be working correctly (lights, etc.)
http://circuitboardmedics.com/ford-m...luster-repair/
I don't know if you've taken care of this yet, but either your soldering wasn't good, or you didn't get the needles back on correctly. If you're not sure what's wrong, there is an option other than bringing the car to a dealer and having them replace the cluster; there is a company that repairs these gauges for $179. You pull the cluster yourself and send it to them, and they'll replace all the stepper motors and reassemble the cluster. Lifetime guarantee on the work too.
Rando
8/25/21 11:12 AM
