S-197 Mustang Help With Forscan to Disable Perimeter Headlamps only
Old Apr 10, 2026 | 09:43 AM
Pierre57's Avatar
Hello I have a 2008 mustang gt and upgrading to oem HID I would like to disable the headlamp perimeter only ,like on factory equiped car . I have Forscan but don't know what to modify in GEM/SJB as built . Can someone help me ? Thanks a lot
Updated Title To Improve Search!
KC
Admin
Old Apr 10, 2026 | 09:48 AM
05stangkc's Avatar
Welcome,
Oem Hid's Were a Popular Topic Back in The Day But Most Did Not Think They Were All That! A Bulb Upgrade Would Be a Much Easier Route. Anyhoo Here Is What We Did To Upgrade Back in The Day. I Don't Know The Exact Way You Turn Off the DRL But Here is Some Info Which Maybe Helpful!
Oh, Found A Forscan DRL Link See Botton Link!
See First PDF For Silver Horse Racing Wiring Cheat! UPGRADING TO HID!
https://themustangsource.com/forums/...stangs-549333/
How To Disable DRL With forscan
https://forum.forscan.org/viewtopic....e+codes#p13010
Related Link
https://forum.forscan.org/viewtopic....tang+drl#p9806
As-Built Info & Link
https://themustangsource.com/forums/...9/#post7090848
KC
Old Apr 10, 2026 | 11:07 AM
Pierre57's Avatar
I love the hid headlamp design .I don't have DLR I speak of the perimeter light when unlocking the car . I know HID cars don't have the headlamp on when pressing unlock but the Fog instead .
Old Apr 10, 2026 | 11:09 AM
05stangkc's Avatar
Oh, I Guess I Jumped The Gun. The Forscan Thread / Forum May Address That.
All The Info Posted May Help Shed Some Programming Light as it Were on Your Update.
I Don't Recall in The Silver Horse Upgrade Having To Do Any Programming Update.
Anyhoo, Checking Out The Info Should Be a Good Step in Your Upgrade Journey.
It's Been 18 Years Back When This Upgrade was First Done So I'm a Bit Rusty on the Whole Thing!
KC
Old Apr 10, 2026 | 11:24 AM
Pierre57's Avatar
thank you ,I can't access ford scan forum I have a licence but I'ont have my invitation code so I'm stuck outside . I will use a morimoto harness for the install .
Old Apr 10, 2026 | 11:26 AM
Pierre57's Avatar
I manage to disable entirely the perimeter light function But I would like at least to have parking light on when unlocking
Old Apr 10, 2026 | 12:06 PM
05stangkc's Avatar
I'm Not Sure About What You are Not able To Access. Oh I Guess Actual Forscan Product Site.
I Just Went into This! Maybe it's Not The Site You are Speaking of But Might Be Useful!
Sorry, Trying To Help!
https://forum.forscan.org/index.php
KC
Old Apr 10, 2026 | 12:35 PM
Pierre57's Avatar
I can not post on the forum it ask me a validation code to register
Old Apr 10, 2026 | 12:43 PM
05stangkc's Avatar
I Get it! I Was Thinking There Might Be an Existing Thread There With Some Overlap info Which Would Be Helpful. Would Be Nice To Post Though!
Well if Anybody With Some Real World Forscan Experience Can Help Our Friend Out Please Chime In!
Updated Title To Perhaps Draw In Someone With Real World Forscan Knowledge!
Bonne Chance!
KC
Old Apr 19, 2026 | 04:27 AM
Pierre57's Avatar
Hello does someone have a solution or a screen cap of as build code on a gt with HID?
Old Apr 19, 2026 | 09:20 AM
05stangkc's Avatar
Check Your Email!
See it That Works!
KC
Old Apr 20, 2026 | 08:12 AM
Pierre57's Avatar
Many thanks . On last thing I would like to , is getting ride of the annoying key in ignition chime .
Old Apr 20, 2026 | 10:22 AM
05stangkc's Avatar
Try This in Last Post!
https://www.s197forum.com/threads/di...or-chime.2520/
Last Post!
Have No Idea if It actually Works!
Get in, close all doors/windows, make sure nothing is set to switch on, put car in neutral if a manual.
You have a minute to do this from start to finish, otherwise you have to restart.
1. Key-in and turn to ACC (not on/start).
2. Watch for the seltbelt dash light icon, it should stay on for a bit.
3. When it turns off, insert and undo the seatbelt 9 times (should be taking the belt out on the 9th cycle).
4. At this point you should see the SRS (airbag) icon come on.
5. When the SRS icon turns off, insert and remove the seatbelt one more time.
6. The SRS icon will flash. When it stops, you're done.
To reverse, just repeat.
Old Apr 21, 2026 | 12:07 AM
Pierre57's Avatar
I will try . But it's rather the chim when turning the key in position start without having a seat belt it sound 4 time
Rebelk81
Nov 22, 2025 03:28 PM
Tony@AnzoUSA
'10-14 Exterior Modifications
Aug 19, 2021 08:31 AM
Ruphix
Ford OEM Parts {Oem Ford Parts Information & Links}
Apr 4, 2008 01:28 PM
metroplex
Dec 28, 2007 10:29 AM
metroplex
05-09 Exterior Modifications
Dec 24, 2007 02:12 PM
