S-197 Fuel tank Fill HELP HELP IS this only me!!!!!
Ive had the same prob with my 06 but it only happens here and their....also sometimes it tells me i have no gas in the tank when their's still bout 1/4-1/2 of a tank left....they said it was a sensor prob with it....but other than that my car has had not prob and it been great
I hit the same snag from time to time. It does seem to happen when I'm in a hurry, so I'll just have to remember to take my time, insert the nozzle, and then pump the gas
Are you kinddin?
Salesman: Oh by the way buyer you might or might not have a problem putting gas in your car if you don't, don't worry about it if you do bring it back because there is nothing that can be done. If you turn the nozzle upside down it'll work fine.
There is the internet and TSB, a lil prior research you would find this out, there is no safety issue and no macanical failure so what exactally do they need to disclose, that it might happen????
Mine has done it 3 time in 2 years, I turn it upside down and whamo fixed...good luck and enjoy everything good about the new car you just bought.
On the rare occasion mine kicks off early you can do as Rob O does.
I think its more of a gas station pump problem as this only happens rarely with mine. If the recirculate tube in the nozzle is obstructed it will shut off early.
phoneman91
1/8/11 07:39 PM
WyoSilver
10/23/07 09:24 AM
