Radio not shutting off when opening door...
Old Oct 24, 2007 | 04:23 PM
GT98's Avatar
I'm having issues with my radio in my Mustang...It just started to happen, I shut the car down and pull the key out and radio is still on like its supposed to, but when you open the door, the radio is supposed to shut off..and its not. I've also noticed that if you try to lock the doors with the drivers door open, the power locks unlock themselves...
Old Oct 24, 2007 | 05:52 PM
theedge67's Avatar
Sounds like the car still thinks the key is in the ignition. Might be a bad sensor in the key tumbler. It won't let you lock the doors if it knows the keys are still in the ignition as a safeguard against locking they keys in the car.
Old Oct 24, 2007 | 06:08 PM
GT98's Avatar
Interesting...I was starting to wonder if this was part of the accident I had last month...guess I'll call the dealer..
Old Oct 24, 2007 | 06:39 PM
theedge67's Avatar
Could be related I suppose. Maybe something got knocked loose in there.
Old Oct 26, 2007 | 10:39 AM
Jnel's Avatar
Just tested this, and radio shuts off when door is opened and key is in, but turned off. Also door locks won't stay locked, which is correct. Hope this helps. Might be 2 diff. problems.
Old Oct 26, 2007 | 06:36 PM
I think there's a problem with the ingition switch. My car still dings some times after I take the key out and open the door. Like the lights are still on or the key is still in the ignition. If I put the key back in and then remove it the dinger will stop
Old Oct 26, 2007 | 06:37 PM
maybe a shot of wd-40 or the like will do the trick??
Old Oct 29, 2007 | 04:24 PM
RottenRonny's Avatar
I would strongly advise against that.
Many years ago, I was the lock guy at a hardware store, and you wouldn't believe the number of locks I've seen F'up because of wd-40. The problem is, once you spray it in there, dust and filings stick to it, and build up in the lock, eventually ruining it.
Old Oct 29, 2007 | 04:44 PM
Sabre's Avatar
Go to an automotive or electronics supply store and specifically ask for "electrical contact cleaner" spray. It cleans and then evaporates, leaving no residue of any kind behind.
Old Oct 29, 2007 | 04:47 PM
GottaHaveIt's Avatar
I had a similar problem , but found that it was the actuator in the drivers door, so what I did was spray ou the key hole with a can of dry-air and twisted the key a few time and it was good again, I was told it may have been the position it was in or moisture in there being a condutor. It never happened again !
PS they do have proper lock stuff that help and not goo it all up.
Old Oct 30, 2007 | 11:28 AM
ShowGT's Avatar
Graphite in the powder form over WD40 first folks.
kponypower
Jun 17, 2020 07:17 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
RCooke08GT
Feb 19, 2017 03:03 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
Sep 30, 2015 07:02 PM
