Question about engine oil
Old Mar 5, 2007 | 07:50 AM
Louie's Avatar
The FORD recommended 5W-20 is not available here, so my dealer has been using 5W-30 instead. I was wondering whether it could cause any problems in the long run. No issues can be noticed so far.
Weather conditions here are mild, with low 30s in winter and low 80s in summer on average.
Old Mar 6, 2007 | 05:52 PM
ravenblack67's Avatar
If the dealer is doing the work, you should be okay. The difference is minor and the only negative is slightly lower gas mileage as the 5W-30 is a bit thicker.
Old Mar 6, 2007 | 05:59 PM
13 MIKE's Avatar
I just changed my oil an hour ago, put in 5w-30 Mobil 1
Old Mar 6, 2007 | 08:39 PM
theedge67's Avatar
You will be fine with 5-30. It will only be slightly thicker once it is warmed up, and will not cause an issue I'm sure.
Old Mar 7, 2007 | 03:17 AM
DynamicmustangGT's Avatar
depends how hard you drive, if it will do anything at all. I hear it makes your engine a slight bit sluggish when cold but when it warms up its better for winter protection for some reason. Cant remember why though
Old Mar 13, 2007 | 05:47 PM
Indystang's Avatar
The first number (5) is its "resistance to flow" at a specified cold temperature, I think around 32 derees F.
The second number (20 or 30) is its resistance to flow at normal operating temperature. Under laboratory conditions, basically better fuel mileage with the 20 weight oil but I haven't read how much better. The lower the number, the better it will flow.
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
bigaaron
1994-2004 V-8
Aug 22, 2015 12:06 PM
Mackitude
Aug 13, 2015 01:05 PM
