Problem
Old Mar 28, 2013 | 07:19 PM
Corstang427's Avatar
Just got my car out to get the cob webs off of her. Let her warm up to operating temperature to let the oil cycle. Changed the oil and took her for a quick run. I noticed when getting on her it kinda cut out for a second at 110mph. I'm thinking that maybe she isn't getting enough fuel. It's has a ford racing tb, Paxton novi 2200 blower, upgraded fuel pump and 39lb injectors. Maybe I need bigger injectors and some upgrade fuel rails ? Anyone know a solution?
Old Mar 28, 2013 | 07:21 PM
run a tank or two of gas through it before doing anything. If it ran fine before you put it away I would think the gas went sour over the winter
Old Mar 28, 2013 | 07:24 PM
Could be, I did fill her up with Sta Bil before she went into storage and under the car cover. Perhaps it was just the fuel. Could be the quality of the 93 I suppose.
Old Mar 29, 2013 | 08:33 AM
Imatk's Avatar
Yep probably bad gas.
Old Mar 29, 2013 | 01:15 PM
If I did put in bigger injectors would I have to change anything?
Old Mar 29, 2013 | 02:28 PM
Imatk's Avatar
Yes the tune would have to be adjusted.
Old Mar 29, 2013 | 03:21 PM
Victorfriessen's Avatar
I have 39lbs injectors as well and also have the paxton 2200,i have cams,longtube headers and Im @ 520rwhp so it cant be the injector being to small,also depends on the flow rate but if it worked fine before,have you checked the maf?
Old Mar 29, 2013 | 03:33 PM
BRADGTCS's Avatar
definitely run some good fuel through her. But did you happen to hit the rev limiter.
Old Mar 29, 2013 | 05:15 PM
No I didn't, was only at 5000 rpm.
Old Mar 29, 2013 | 05:16 PM
Yes that was the first thing I checked.
Rando
Aug 25, 2021 11:12 AM
Mpaps
Oct 11, 2017 08:06 PM
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
