Power window calibration?
Old May 15, 2007 | 05:34 PM
Vallee's Avatar
Is there such a thing? Guys help,
I recently installed a PIE FRD04-AUX adaptor in my 2005 mustang and it killed my battery, later I found out it may be the SW version in the PIE AUX adaptor unit , apparently PIE is are aware of this and are sending a new one out to me...
(don’t they verify there stuff before sending out the field)
Now the battery is charged back up and all is well or at least I thought so, my power windows will not go up when I shut the door, that is, if they are all the way up and the door is opened it drops like it normally would about ¼” or so, then when you shut the door the windows stay down and don’t return up WTF. In addition, I noticed that the windows go down more than before and kinda bang, or bottom out quite hard when you put them all the way down. I thought I read somewhere about calibrating the windows to control how far they go down and up? Help…
-Adam
Old May 15, 2007 | 05:51 PM
DoctorQ's Avatar
try this link.. the most comprehensive window reset post I've seen:
http://forums.bradbarnett.net/showpo...0&postcount=10
Old May 15, 2007 | 06:06 PM
Vallee's Avatar
DoctorQ,
you are the man!
Old May 15, 2007 | 06:18 PM
Vallee's Avatar
it worked!!!!!!
Old May 23, 2007 | 07:16 AM
GottaHaveIt's Avatar
My 10 yr old son now 11 yrs whipped out the manual from the glove box read as I was driving and fixed it, So we all at times get lazy and don't read the book , I'm surprised it was in there. seems to happen when a battery cable is disconnected.
Old May 28, 2007 | 06:55 PM
DynamicmustangGT's Avatar
lol smart boy you got there
Old May 29, 2007 | 09:11 AM
kevinb120's Avatar
You have to be very cautious with a coupe if they get stuck all the way up, it can hit the hard moulding and yank the side mirros loose.
Old May 29, 2007 | 09:22 AM
That's for sure when it first happened I thought that it was going to pop out the window when I tried to close the door, so if the window is all the way up don't force it, who knows it may not be covered, so get out the book, or sit in seat roll down then pull toggle up & hold for 2-3 seconds and should be good. Yup Kids are great they are such a HUGE source of inspiration,and they don't miss a thing they see & record all we do and only better it!
Old Jun 3, 2007 | 10:13 AM
dprestia's Avatar
window works
Thanks I did the window set-up and they work just fine.
Old Dec 18, 2010 | 10:45 AM
fastrek82's Avatar
Will that drain the battery?
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
