my '05 is leaking
my '05 is leaking
Okay, I saw the thread about the '05 GT Vert having water leaking problems and them having water on the passenger side floor. I have a similar problem now happening in my '05 GT Coupe. ![Nonono](https://themustangsource.com/forums/images/smilies/nonono.gif)
Two days ago I was driving to work, lately here in FL. we have been having some killer rainstorms especially in the Tampa Bay area, and it happened. As I went up the parking ramp of the parking garage at work I heard a sloshing sound. When I looked at my passenger floor board it sounded like someone poured a small bucket of water out onto the carpet and I immediately noticed a puddle at least a couple of inches deep on the floor. Unfortunately it kept raining the rest of the day and the following day. The night of the incident I put the car in the garage to try and find the problem.
I took the passenger footwell plastic off and climbed under the dashboard to look up and see if I can see a water path. There is no water path. I searched the forums and am making this post to see if someone can help me. All you DIYers on this site seem to usually have more knowledge than a technician for Ford.![Headbang](https://themustangsource.com/forums/images/smilies/headbang.gif)
The car stinks like mildew now and I didn't see a water trail anywhere other than initial droplets falling off off the plastic under the dashboard when it happened. So now I'm imploring you for help.
Is there something I should be looking for? Do I need to take apart the plastic parts on the outer cowl? Do I need to take my entire dashboard apart? Do I need to do all of the above?![Confused18](https://themustangsource.com/forums/images/smilies/confused18.gif)
I have all day Fri. off to work on the problem and dissect the car.
As always, thank you in advance for any help you guys can offer.
-Frank
-Frank
Water leak
Mine leaked and I used the Ford TSB to fix. I found the problem to be the outer black window molding which had a bad foam seal. I unscrewed the molding, used a clear RTV sealant, and done. It took me months to get rid of the mildew smell. I used two of the Groitt garage one time use ordor eliminator kits. All is good now. Good luck!
Thanks for the quick replies guys! I totally missed that last page Glenn. Prolly in my worry I just missed it.
Data, thanks for the TSB#. I've never used a TSB before. I know, pretty pathetic.
Roger, thanks for the info about the mildew eliminator kits. I will definitely use it.
On a side note, I haven't had this issue before but I did have my windshield replaced recently due to someone putting a rock through it. Heh. Could they have not sealed it right? I mean it was raining hard after I got the windshield and it didn't do it it immediately. I'm just paranoid cause i already had the door panels peel off. Ugh.
Again, thank you three for immediate answers and suggestions.
