Metallic rattling under my car
Old Dec 5, 2006 | 07:55 PM
V8Mike's Avatar
I have an 05 GT premium manual with 20k miles with an irritating rattle. Right after starting the car and before it warms up, there is a very distinct metallic rattling sound. It only happens until the car is warm, at which point it stops. I first noticed this about 3-4 months ago, and with the recent cold-snap in Chicago the sound is much much louder now. On warm days the rattle is much less pronounced. Also, it seems to be coming from somewhere near the front part of the car, basically right under the shifter (but under the car). I have flowmaster axlebacks but the sound started before I put them on so I'm fairly positive that's not the source of the sound.
I'll end up bringing it in under warranty to check this out soon. Anyone with any ideas of what this could be? I don't know what the hell I'm doing, so even if I crawled under there I doubt I could tell where exactly the noise is coming from . Thanks in advance for any info you can give me before I take it in!
Old Dec 5, 2006 | 08:32 PM
94tbird's Avatar
its a faulty exhaust hanger. warranty will cover it
Old Dec 5, 2006 | 08:40 PM
Enfynet's Avatar
Check the bottom of the transmission bell housing. A lot of 05's were missing the bottom 2 bolts. Do a search, I'm sure the thread is still around here.
Here try this thread: http://forums.bradbarnett.net/showthread.php?t=15391
\/--- The flowmaster rattle wouldn't be near the front of the car.
Old Dec 5, 2006 | 08:41 PM
LEO_06GT's Avatar
Do you happen to have flowmasters??
Old Dec 5, 2006 | 09:36 PM
FLAstangx3's Avatar
Should be the Hanger. Happened to a lot of us. There is a TSB on it. Not a biggy, but definately a nuisence.
Old Dec 5, 2006 | 09:47 PM
HOTLAP's Avatar
That was my thread and is probably your issue. Ford left out the two lower bolts in the tranny bell housing (lower front) and dust shield will rattle like crazy until the car is warm....sounds just like an exhaust shield rattle and will drive you nuts! Get the bolts from your local Ford dealer and install and your noise should be gone
Old Dec 6, 2006 | 06:46 AM
Infinity's Avatar
Pics and more info PLEASE! I know my exhaust rattles on the driver's side, I just can't find where.
Old Dec 6, 2006 | 08:13 AM
SteelTownStang's Avatar
Although I've been under the car before, I can't remember what the cats look like. An older Stang that I've own had the same sound. It was caused by a weld that broke loose on the heat shield that was attached to the cats. Crawl under the car and hit the exhaust with a rubber hammer when it's cold. If it's the exhaust, you might be able to track "it" down. You already mentioned the it started before you installed the Flows, so it doesn't appear to be them which would have been my first suggestion...
Old Dec 6, 2006 | 09:38 PM
V8Mike's Avatar
Thanks all for the info. I love this friggin place.
Old Sep 1, 2007 | 08:29 PM
HL22's Avatar
I'm trying to reply to each of these threads since this rattle was so annoying and embarassing.
Unbolt the two lower fasteners. Put 1-2mm washers in between the plate and the bell housing. Rebolt and the noise should be gone.
Old Sep 10, 2007 | 02:16 PM
imyy4u's Avatar
try this:
http://www.mustangforums.com/m_3772748/tm.htm
Spiker52
Jul 4, 2018 06:34 AM
RRRoamer
Jan 19, 2017 05:27 PM
apial
Sep 6, 2015 10:40 AM
firstang001
'10-14 Exterior Modifications
Aug 4, 2015 07:43 PM
BentCopper
Jul 21, 2015 08:35 PM
