Master Cylinder leaking?
Old Dec 4, 2006 | 04:13 AM
WarBird69's Avatar
Hmmmm been a while since I've been here... forums are re-arranged...
Anyway, I'm looking for info (possibaly a TSB) about leaks from the cap of master cylinder's on 05+ Mustangs (mine is an 07). I'm taking the car in for its 5k oil change next week, and plan on letting Service take a look at the leak (since its under warantee). Thanks!
Old Dec 4, 2006 | 05:39 AM
metroplex's Avatar
Some claim that it is because the top of the reservoir is not flat, thus the gasket cannot seal properly. I found that the gasket in the cap isn't thick enough. I can hear it rattling around when I shake the cap.
Wrapping the neck of the reservoir with Teflon tape (plumbers tape) about 2-4 times will be a good temporary fix.
And as you have found out, it is still a problem with 2007s (even the ones that are currently rolling out of Flat Rock). Ford is ignoring the problem just like the smart junction boxes that are shorting out from water leaking in.
Old Dec 4, 2006 | 05:58 AM
some have had theirs replaced by the dealer with no more problems
Old Dec 4, 2006 | 06:16 AM
metroplex's Avatar
Good for them. It's too bad Ford is still using the faulty parts at the factory.
Old Dec 4, 2006 | 02:17 PM
Centurion96's Avatar
Make sure it's the yellow Teflon tape which is made for petroleum based products.
BB
Semper Fi
Old Dec 4, 2006 | 03:10 PM
metroplex's Avatar
BB
Semper Fi
Thanks for the tip. I'm not sure where glycol based products fit though. I use teflon plumber's tape for ECT/coolant temp senders that thread into the coolant crossovers without any problems. Since anti-freeze is 50% ethylene glycol, I'm sure regular plumber's tape won't have a problem with periodic exposure to 100% glycol based brake fluid.
The yellow is for gas line connections (as in natural gas):
The yellow tape is heavier and is for use on gas line connections. Never use regular, white, teflon tape on gas connections.
http://www.acmehowto.com/howto/homem...ral/teflon.php
I've seen a thicker pink tape before but I'm not sure what it is used for.
Old Dec 4, 2006 | 03:11 PM
Little Black Pony's Avatar
There is already a super long thread here...
http://forums.bradbarnett.net/showthread.php?t=48855
Old Dec 4, 2006 | 03:14 PM
metroplex's Avatar
The more the merrier.
Old Dec 5, 2006 | 05:42 PM
WarBird69's Avatar
I knew that thread was somewhere, however, when the Service forum went away I lost it. Thanks!
Car is going to delaer next Wednesday for 5k oil change + a look at the leaky MC
Gill5oh
Oct 6, 2017 10:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 23, 2015 03:21 PM
bconboy
Sep 18, 2015 08:18 AM
bconboy
Sep 10, 2015 02:31 PM
