Knock up front? Troubleshooting help needed.
Old Nov 13, 2006 | 07:01 AM
jdruid's Avatar
Angry Knock up front? Troubleshooting help needed.
I am starting to experience a "knock" up front. I think I narrowed it down to my right shock tower. In any case, I took both wheels off, made sure everything was tight again but still got the knock. It sounds like it is getting louder over the past few days.
I have Steeda Springs and FRPP shocks. They are about 8 months old. Never abused, no huge pot holes hit, just one day it started the knock.
Any thoughts on where to begin to troubleshoot?
Old Nov 13, 2006 | 07:31 AM
06GTwJUICE's Avatar
jack up your car with weight off both wheels and recheck your swaybar endlinks. With load on the tires you might not be able to tell they are loose.
I had a noise that got progressivly worse and it turned out to be that.
I tightened them not even a full turn and the noise stopped.
my guess... endlinks are a little loose.
Old Nov 13, 2006 | 08:19 AM
SixtySix's Avatar
It could also be the upper strut bearing caps. Mine started knocking a few months after I did my springs and has gotten progressively worse. I too checked the end-links more than once, and that wasn't it for me.
When I did my springs, shortly there-after I also did my longtube headers, and BMR K-member. My alignment was noticeably off, but didn't do anything about it. I'm guessing that with my alignment being as off as it was, it put a little more pressure on the upper strut bearing caps and they failed. So this weekend I'm putting Ford Racing Struts on and new upper strut caps and I should be good to go. Oh, and next weekend....an alignment. Don't want to do this again in a few months
Oh and in case anyone asks, yes, I had these replaced when I first got the car under the TSB for the strut clunking on the 05's.
Old Nov 13, 2006 | 10:38 AM
jdruid's Avatar
Sweet. I will try those 2 things. My car was built in July so hopefully it already had the TSB fix by then.
Old Nov 13, 2006 | 10:48 AM
SixtySix's Avatar
If it ends up being the strut caps, they're cheap. I picked em up for like $24.00 for both of them.
Old Nov 13, 2006 | 01:51 PM
06GTwJUICE's Avatar
It's possible like sixtysix said athat it's the strut caps.
my right one was squeeking and I replaced it at the same time I checked the bolts, i just made sure everything was tighter when i put it back together...
and yea.. those caps are cheap.
Old Nov 19, 2006 | 04:47 PM
jdruid's Avatar
So it was the end links. Tightened them up today. I contacted Steeda too and they mentioned they were coming out with strut caps in December. Nice upgrade for Christmas
09-gt/cs
Oct 15, 2015 10:03 AM
RoushRS3
Sep 29, 2015 08:03 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
