Interior Rear Rattle Fixed
Old Aug 4, 2006 | 08:11 PM
Mark S.'s Avatar
I'm removing my posting...the rattle is back!
Old Aug 5, 2006 | 06:05 PM
2005GTDELUXE's Avatar
what did you think that they did before that may have stopped it.
Old Aug 6, 2006 | 12:10 AM
Mark S.'s Avatar
I thought that the rattle was coming from my driver's side rear seatback since it was not fully latched...the rear seatback is now fully latched and it's seatbelt is secured tight between the seatback and the rear armrest area, however, the rattling/creaking continues whenever I hit a bump in the road. It's back to the drawing board. I also pressed in the C Pillars in the rear in case they were the culprits contributing to the creaking noise. On my way to work today...the noise appears to have stopped...for how long...I don't know...darn gremlins!!
Old Aug 6, 2006 | 07:38 AM
Originally Posted by Mark S.
darn gremlins!!
this is the answer
Old Aug 6, 2006 | 07:53 AM
SoFlaBoss's Avatar
Try checking out inside the trunk, where the liner attaches to inside the rear quarter panels with push-pins, in the top section of the liner (both sides). I replaced my rear bumper cover the other day and noticed that this push-pin fits into a clip that is loose, which rattles metal against metal, possibly squeaking too. Just tap on the inside liner a little and you'll hear what I'm talking about. Just a thought.
Steve
Old Aug 6, 2006 | 08:27 PM
Mark S.'s Avatar
SoFLO5GT, I'll be sure to give that a shot...it's amazing...the noise seems to come and go. It was fine this morning as I drove home (about 20 miles)...since I was just below a half tank of gas I decided to stop and fill up...once I did that, the noise returned...there are times that it can really drive me nuts...however, with the music on (even only a quarter volume), I can't hear it. Sounds more and more like creaking, than a tapping. Go figure!
Old Aug 11, 2006 | 03:50 PM
svt boost's Avatar
i have the same problem!
it happens paradoxically for me on bumps, and not all of the time. I cant tell what the **** thing is!
Old Aug 13, 2006 | 01:17 AM
05gtIn408's Avatar
..I too have the dreaded squeak/ rattle coming from the rear of the car and its driving me mad trying to find it but it does sound like its coming from the rear of the car I'm thinking of putting in some sound deadner in my trunk and some other spots to see if it at least that will cover it up since i cant seem to find where in the rear its coming from...
Old Aug 14, 2006 | 10:05 AM
Tboned's Avatar
Mine was an exhaust shield rattling..
Old Aug 15, 2006 | 11:42 AM
icemant180's Avatar
check the plastic cover over the trunk lock assembly. Mine was rattling when I cranked up the shaker. A small piece of duct tape placed on the back side where it can't be seen did the trick.
Old Aug 15, 2006 | 07:38 PM
lethaljay's Avatar
I also experienced this same rattle for the longest time and it made me furious! One day I hopped into the back seat and banged on the back ledge under the window and realized every time i banged on it, it would rattle. I then crawled into my trunk and banged on the ledge from the underside. I found a small section where it looked like a tack-weld didn't get fully umm 'tacked'? I then bent the corner in a way that the rattle was completly removed.
Old Aug 19, 2006 | 07:49 AM
Mark S.'s Avatar
icemant180 and lethaljay, I'll give it shot...thanks!
Mpaps
Oct 11, 2017 08:06 PM
Fords4Ever
Oct 30, 2015 09:07 PM
seaclam
Sep 25, 2015 01:29 PM
DrisStang
Sep 14, 2015 06:20 PM
