Interior light
Old Dec 4, 2024 | 06:36 PM
Weylinj's Avatar
Interior light
Guys, I just picked up a 2007 GT for a good price and am slowly fixing the little annoying things. I am stuck on interior lights. They don’t work at all. No trunk light. No map lights. Doesn’t work with dimmer **** or opening door. Nothing. I haven’t found a blown fuse. Any ideas?
Old Dec 4, 2024 | 06:51 PM
05stangkc's Avatar
Welcome,
I Would Check For Any Body Codes. See Second PDF. I Would Advise To Check Cowl Area For Water Intrusion into SJB. See Link! These Days Any New To You S-197 Mustang Almost Warrants a Check For The Water Intrusion As it Can Cause a Host of Problems Now & Down the Road!
https://themustangsource.com/forums/...26-7-a-550617/
KC
File Type: pdf
Old Dec 4, 2024 | 07:04 PM
Weylinj's Avatar
Welcome,
KC
So I should check for codes even with no lights or check engine light?
Old Dec 4, 2024 | 07:07 PM
05stangkc's Avatar
Yes if You Have a Reader Capable Of Pulling Body Codes It Would Not Hurt. If You Don't Many Parts Houses Will Check Them. Just Make Sure Their Reader Can Pull More Than Just The Standard P-Codes. A Fault Will Not Always Set a Light.
Read Through The Pdf's And Choose Your Own Course of Action. I Added Wiring Diagrams For Interior Lighting As Well! I Am Thinking You Got Some Crusty Connections on Some SJB Connectors But That is Just a Guess. Seems To Be a Pattern Here Lately For Folks Picking up A Used S-197.
KC
Old Dec 4, 2024 | 07:15 PM
Weylinj's Avatar
Thanks. I will start down that path tomorrow. Not sure if my reader is capable but I will see.
Old Dec 4, 2024 | 07:20 PM
05stangkc's Avatar
You Are Welcome!
If You Need Anymore Docs LMK!
I Think This Will Give you a Good Start and at The very Least Know The Shape of the SJB To Prevent Future Issues!
KC
Old Dec 12, 2024 | 01:36 PM
Weylinj's Avatar
I haven't started to track this down yet but the cold weather has identified another problem. MY defroster isn't working. Heat only blows out of dash vents. does any of this go through the SJB?
Old Dec 12, 2024 | 01:41 PM
05stangkc's Avatar
Hvac Thread! & Also Common Issue is Blend Door Motor Failure. A Lot of Time You Will Hear Clicking When Changing Vents!
https://themustangsource.com/forums/...-noise-548146/
https://themustangsource.com/forums/...l-pdfs-551104/
KC
Old Dec 12, 2024 | 01:53 PM
Weylinj's Avatar
I actually ordered the defrost actuator and it came in a few days ago. No clicking it just doesn't switch from the dash vents. I am off work tomorrow so hopefully I can get at least 1 of these 2 problems figured out.
Old Dec 30, 2024 | 01:40 PM
Weylinj's Avatar
Just wanted to give an update on my issues. Finally got some time to dig and find the issue. Let this be a reminder to check the easiest things first. I spoke with the previous owner and the interior lights not the defroster worked the entire time he owned it.
Interior lights- had no bulbs. putin new bulbs and they work like a champ.
Defroster- went to replace the actuator and found it unplugged. Plugged it up and it seems to work fine.
Old Dec 31, 2024 | 08:22 AM
Weylinj's Avatar
I guess I celebrated too soon. Last night on my way home I noticed a faint glow from the interior lights. once i stopped the car and turned off headlights and Key it was still on. Lights did go all the way off once it timed out. Did some swapping with my other car and noticed it only does this with the LED bulbs I bought yesterday. and only then if they are both installed. Anyone know why this might be happening?
Old Dec 31, 2024 | 08:48 AM
05stangkc's Avatar
I Have Heard Complaints Using Certain LED Bulbs in Fords Causing Odd Issues!
KC
Old Dec 31, 2024 | 08:55 AM
Weylinj's Avatar
KC
I was thinking this was the case. that was all the parts store had available. but was thinking it could be a switch. Even though the light/cover in my wifes 2011 looks the same, the whole thing wont plug in. Swapped one bulb and it works fine. Just weird.
Baolee24
1994-2004 V-6
Feb 25, 2014 10:05 PM
Mulepick
Mar 14, 2013 09:02 AM
stangs&thangs
Oct 16, 2012 05:14 PM
Knight
Oct 11, 2006 06:46 PM
Redbaron93
Aug 8, 2006 01:41 PM
