Chattering valve train after cam install
Old Jan 7, 2025 | 04:02 PM
Thumpin3v's Avatar
Could anybody help point me in the right direction to what could be causing the chattering seemingly near the intake manifold closer to passenger side. I just installed cams about a week ago, the intake manifold and injectors never got pulled and sat how they are during entire install, so I don’t think it’s either of those. Thanks in advance! Car is 2006 mustang GT with Ford performance “hot rod” cams. There should be a video attached
File Type: mov
Old Jan 7, 2025 | 04:32 PM
05stangkc's Avatar
Welcome,
I'm Going To Post The RH & Lh Cam Change Process From The Shop Manual. Might Review and See if You Missed a Step.
KC
File Type: pdf
File Type: pdf
Old Jan 8, 2025 | 09:56 AM
svopaul's Avatar
Service Manager
Always go back to the last thing you did or touched...noises can resonate to areas other than the problem. Did you do valve springs too or just cams? Are you certain they didn't move a tooth? These are interference engines so if the timing isn't dead on then you get piston to valve contact.
PonyXpress
2012-2013 BOSS 302
58
Jul 23, 2014 03:57 PM
wallace
Aug 26, 2013 07:10 PM
10gt
4.6L GT Modifications
Nov 20, 2012 06:28 PM
dansgt
Mar 7, 2011 11:47 PM
Alloy Stang
77
Nov 26, 2008 11:35 AM
