Hood shake/flutter
Old Mar 26, 2008 | 12:56 PM
flieger67's Avatar
Hood shake/flutter
After a long absence, I need to say a big "howdy, y'all".
I wanted to ask if there is a TSB or anything similar related to hood shake/flutter. I did a search on the forum but I couldn't find a TSB per se. I had to have my hood replaced at one point due to hail damage (I wish my company had covered parking, but that's another story) and I've noticed some slight hood flutter at highway speeds which I don't remember seeing with the original hood. For what it might matter, the dealership where I bought my car did the repair work.
Anyways, I'm going in tomorrow for recall work on the passenger-side front airbag and I wanted to try to get the hood addressed at the same time.
Thanks for any help or advice you can offer.
Old Mar 26, 2008 | 12:58 PM
Some people have adjusted the hood stops up a turn or two and all was fine.
Old Mar 26, 2008 | 01:05 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Yeah, adjust the rubber hood bumpers/stops and that's all that can be done. No TSB, warranty issue, etc. Very common problem.
Old Mar 26, 2008 | 01:20 PM
flieger67's Avatar
Thanks for the info, folks. I must have incorrectly remembered the existence of a TSB.
Again, thank you for the quick responses.
Old Mar 27, 2008 | 06:32 AM
Mark S.'s Avatar
Problem is that the high pressure air that builds up under the hood (at higher speeds and certain wind angles) and it has nowhere to go...so that's why you get the flutter...its doesn't help that the hood is made of aluminum for weight reasons and aluminum is a bit flimsy. They should have kept the fiberglass/re-enforced plastic for the hood (similar to the 99-04 models).
Old Mar 27, 2008 | 06:55 AM
adrenalin's Avatar
If adjusting the hood stops doesn't resolve the issue (as it didn't for me) you might end up installing hood pins. That stopped the hood flutter issue on my car
Old Mar 27, 2008 | 04:53 PM
Francesco's Avatar
At higher speeds the rubber hood bumpers dont work at all. So I've installed a special rubber seal under the hood. So look at this:
Additionally adjusting the hood-hinge and... it works fine for me.
Old Mar 27, 2008 | 05:17 PM
MustangLynda's Avatar
My hood shudders too, I adjusted those stops and it's better but not gone. Hood pins are out of the question - how retarded would that look on a bullitt
So if I did something like this then how else will air get to my engine, specifically my intake?
Old Mar 27, 2008 | 05:27 PM
slowjoe24's Avatar
Mine does this at high speeds................makes me nervous
Old Mar 27, 2008 | 05:50 PM
07S197's Avatar
Swamp Donkey Man Cans
No kiddin.....me too. I pulled over the first time I saw it thinking the hood wasn't latched all the way down. I only notice it on the drivers side. I tried adjusting that bump stops on the corners but they pushed the edges of the hood up above the fenders. I had better luck with adjusting the latch down.
Old Mar 27, 2008 | 06:17 PM
slowjoe24's Avatar
Was the latch loose??
Old Mar 27, 2008 | 06:25 PM
07S197's Avatar
Nope not at all, I used a small reamer to elongate the holes in the latch and then adjusted it down. At the same time I raised the two bumper on the corners up about half a turn. It's all nice and level and has helped quite a bit. It's much better than it was before, used to look like the hood was going to come off.
Old Mar 27, 2008 | 06:29 PM
slowjoe24's Avatar
Okay..............I'm going to try some adjusting before I get worried!! Thanks
Old Mar 27, 2008 | 06:55 PM
07S197's Avatar
Funny thing about this is that my 2004 F-150 had a similar problem but at the cowl end of the hood opposed to the leading edge. Fords fix was to run a piece of vacuum tubbing inside the hollow seal where the cowl and the hood meet, didn't do a thing to fix the problem. On my 07 Mark LT they use a new style seal that is much heavier and stiffer, doing the same thing as the vacuum hose. But the problem is gone, so I guess it worked.
Old Mar 27, 2008 | 08:23 PM
My hood fluttered at just 70 mph, and at 100 mph it looked like it would raise 3/4" at least just scary. Like the old school look of hood pins and probably was going to do the mod anyway. Shelby billet hood pins problem solved. First class product and beautiful look.
Old Mar 28, 2008 | 01:29 PM
DynamicmustangGT's Avatar
I have hood pins, but when I had adjusted the stops all was fine.
Old Mar 28, 2008 | 01:35 PM
slowjoe24's Avatar
Can someone show a pic of the adjustment stops you are refering too??
Old Mar 28, 2008 | 02:06 PM
I lust for a M24
Look at the far right corner of the upper tie bar, right next to the headlight mounting tab. The right one is hidden directly behind the prop rod for the hood in the picture.
Old Mar 28, 2008 | 02:08 PM
slowjoe24's Avatar
May 3, 2026 05:42 AM
yabutt
Oct 23, 2015 01:05 PM
TerryD
Sep 28, 2015 11:48 AM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
