High Pitched Wind Noise?
Old Nov 1, 2007 | 10:49 AM
SD CALSPCL's Avatar
I seem to have developed a high pitched, shrill,wind noise at high, sustained, speeds. It starts at about 73 and gets really loud (and, annoying) at a steady 75. 90% of my driving is at this speed.
I have tightened the external mirrors, and worked the trim at the bottom of the windshield, which seems to have reduced it quite a bit. But, it is still there. The windshield has never been worked on.
Has anyone else experienced this? Any suggestions for where else this may be coming from. Any information or suggestions are appreciated.
Old Nov 1, 2007 | 10:50 AM
ShowGT's Avatar
Are you sure the door windows are all the way up? May need some adjustment?
Old Nov 2, 2007 | 01:03 PM
scramblr's Avatar
Is your shorty antenna a solid piece, i.e., does it have the curves on the staff like the OEM one? If it's a solid piece, that's probably your problem. Took me a few months to figure it out and I have the same thing above 70mph.
Old Nov 2, 2007 | 03:36 PM
SD CALSPCL's Avatar
The windows are up and tight. I washed her yesterday and ran a heavy stream of water around the molding.
And, yes, I have the solid shorty antenna. Thanks for the advice on this, it drives me nuts since so much time is spent of the interstate.
Old Nov 2, 2007 | 04:07 PM
Eduardo de Sousa's Avatar
Got same noise! Short Antenna too. How did you sort it? Put back old one or is there a fix?
Old Nov 2, 2007 | 04:14 PM
scramblr's Avatar
Take it off and go for a test drive. Bet ya that's it.
Kooks headers and music cranked up fixed it for me!!!
or find an antenna that has the wrap around it like the OEM. This breaks up the wind and you won't get that sound. You could also cut the OEM antenna down and even put the little ball back on it. That's been done a bunch of times.
Old Nov 10, 2007 | 11:46 AM
SD CALSPCL's Avatar
Finally got the chance to cut down the stock antenna. Took her for a run this morning, and no noise.
Scramblr: Thanks for the advice. I was at Rhein Main in '79 with a new Silver over Black Mustang Cobra...loved the run to work and home. Glad to see you are still showing the flag on the bahn. Cheers.
Old Nov 10, 2007 | 02:28 PM
scramblr's Avatar
Glad it worked out for you!!!! I was at Ramstein from '00 - '06 and now up at Geilenkirchen (NATO) base on the German - Holland border for a couple more years. Autobahn's are a blast in these cars.
Old Nov 15, 2007 | 05:31 PM
Dineau's Avatar
So if I read this correctly the short antena was the issue ?
And you decided to replaced it back with a modified OEM antena ?
Old Nov 17, 2007 | 11:09 AM
SD CALSPCL's Avatar
That's correct...the shorty antenna, without the wrap, was the problem, at around 75 mph.
I cut the stock antenna down, which has the wrap around it, and used the ball from the shorty for the top, and no more wind noise.
May 3, 2026 05:42 AM
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
ricky1728
Feb 11, 2016 07:25 PM
