Gas Cap
Old Dec 6, 2009 | 12:05 PM
TheDarkSide's Avatar
Question Gas Cap
Yesterday I got into the car to go to work and when I start my car, the display screen says "Check Fuel Cap". So I get out, go to the back, and check the cap. It was loose. No big deal. I screw it into place and hit the reset button. I'm about halfway to work and the **** warning comes on again. I go all the way to work and park, then I check the cap... its tight! So this happens again when I go to start the car to come home and it keeps throwing the warning. Last night when I finally got home I undid the cap and checked it. No scratches, no cracks, the rubber ring around the top is not discolored or dented or torn or anything that would normally show a faulty ring.
So I'm completely baffled about this and was wondering if anyone had any ideas besides buying a new gas cap. And do I buy an aftermarket one or do I go to a dealership to get one?
Old Dec 6, 2009 | 12:33 PM
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
I had the same thing go on with my 2001 Intrepid. all I had to do was remove the cap and put it back on. It was like there was a vaccuum or somrthing that would trigger that check engine light.
Old Dec 6, 2009 | 12:40 PM
I did that several times. Unscrewed it, removed it, then screwed it back in and restarted the car. It still keeps doing it. And I noticed the filler neck moves a bit when I push on it. I'm sure I'm just beign paranoid now. lol.
Old Dec 6, 2009 | 01:00 PM
Official Fluffer
Well if you get too paranoid then I can take the car off your hands.
Old Dec 6, 2009 | 01:13 PM
lol! not that paranoid!
Old Dec 7, 2009 | 05:03 PM
you'll need a new gas cap. you can probably get one from an auto parts store, which should do the trick, though I'd probably go for OEM replacement, just to be certain
Old Dec 12, 2009 | 08:42 PM
Scott's Avatar
I thought that all the 2010's came with that new capless fuel system? Or should this be in a different forum.
Old Dec 12, 2009 | 08:50 PM
theedge67's Avatar
If I remember right, it takes several drive cycles for the message to go away. Keep driving it for a week, and if it doesn't go away after that, then look into a different cap.
Old Dec 12, 2009 | 08:51 PM
stangfoeva's Avatar
MOTM Committee Member
they do, this is posted in the wrong forums
Old Dec 12, 2009 | 09:47 PM
MadGT's Avatar
Legacy Tms Member
or, disconnect the battery once and then connect.
Old Dec 13, 2009 | 11:39 AM
It was accidently posted in the wrong forum. Completely my fault and I ask any mod that sees this to move it. I apologize guys.
And theedge67, it did go away as it cycled itself out.
Old Dec 13, 2009 | 02:16 PM
stangfoeva's Avatar
no worries man
hope i didn't sound like a douche with my response lol
Old Dec 13, 2009 | 08:11 PM
Oh not at all! lol
Old Dec 13, 2009 | 08:39 PM
GottaHaveIt's Avatar
you can reset it all disconnect the battery and hook it back up ?
Old Dec 14, 2009 | 01:19 AM
theedge67's Avatar
Glad it worked itself out. I don't know why those sensors take a few cycles to reset, to me that is stupid. Why not just show the light when it is a problem, and as soon as it is not a problem, the light turns off? That would make sense though, so they couldn't do that....
Old Jan 3, 2010 | 08:06 PM
Kahdir's Avatar
With some new cars it requires the code to be cleared with a dealers scan tool...
Old Jan 5, 2010 | 07:13 AM
BEW119's Avatar
TMS Legacy Member
Just a heads up, check the filler neck and tube. This happened on my explorer, and the tube had to be replaced.
Old May 4, 2013 | 10:43 AM
Happster's Avatar
Getting one in my 1998 GT. Gas cap is fine. Just replaced the fuel pump with a high volume pump, the filler neck seal and a sensor on the top of the tank. I don't know where to begin. Any way to run a pressure check and find the leak? I did bend one of the plastic hoses going to some external component that has to be an emissions gadget when reinstalling the tank. But it doesn't look cracked. There is a rubber hose adjacent the filler neck that looks pretty tired...maybe I'm answering my own questions. Any help appreciated.
Mpaps
Oct 11, 2017 08:06 PM
NC14GT
Sep 10, 2017 04:47 PM
unnoticedtrails
Jul 17, 2017 11:10 AM
mx5jhb
Sep 30, 2015 04:44 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
