First rattle in my car
Old Jan 22, 2008 | 02:45 PM
Scarpi's Avatar
Ok my 05 has just developed a rattle. It comes from the dash above the tach on top of the dashboard. As a matter of fact you can stop it by pressing down on the top of the dash above the tach. It mostly happens when the outside temp is cool. I hate to have the dealer take apart the dash to fix it (read, "I don't trust them"). Is there a fix that I can try for this. I think I remember someone here mentioning a rattle above the tach but I don't remember how they fixed it. Any ideas appreciated.
Old Jan 22, 2008 | 08:41 PM
Rash's Avatar
You have an 05, and you're just now getting your FIRST rattle? You are one lucky sob.
BTW, I have the same rattle (as well as several others) and haven't yet found a solution. I even took the the front of the dash off (gauges and all) and put foam tape on everything I thought could be causing it. Didn't work. I give up. Good luck.
Old Jan 22, 2008 | 09:07 PM
Scarpi's Avatar
I found out that a friend of mine here in town, works for a Ford dealership and he had the same rattle in his 05. He had the dealership install sound insulation and that fixed the problem. He also said that the 07 cars come with that insulation. So I will be bringing my car to them and hopefully that will fix the rattle in my dash.
Old Jan 23, 2008 | 05:20 AM
Rash's Avatar
If possible, please update us on exactly where they put this insulation. Thanks.
Old Jan 23, 2008 | 07:22 AM
Scarpi's Avatar
Will do! I thought it was interesting that the 07s come with this insulation in the dash.
Old Jan 23, 2008 | 12:42 PM
azoufan's Avatar
Amazing that this is your first rattle. My first rattle was fixed by letting several other rattles settle in and get to work. I barely notice that first rattle any more.
Old Jan 29, 2008 | 07:57 PM
AshTang's Avatar
Same rattle same spot for me. I have had a paycheck stub stuffed in at the pillar to push down on it in this cold weather. Once it is warm it is not so bad. Love my car, hate the rattles.
Shawn
Old Jan 29, 2008 | 08:13 PM
theedge67's Avatar
I had the dealer install a few felt strips between the a-pillar and the dashboard. That is where the squeak/rattle is probably coming from. It was a simple fix, and did not require the dash to be removed. Just the a-pillar cover.
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
apial
Sep 6, 2015 10:40 AM
f1-cobra
Aug 1, 2015 08:02 PM
roushcollection
Jul 28, 2015 02:08 PM
