'Clacking' noise when applying brake...
When backing into my driveway, there's a distinctive 'clacking' noice coming from underneath and towards the back of the car when applying brake.
Sometimes I can hear it when going forward, too.
I did a search of the forum and couldn't find anybody else with this problem.
Any insights would be much appreciated
legacy Tms Member
Two ongoing issues driving me nuts...
The first one is detailed above.
No resolution on it. I just know it will come back to bite me in the backside once the warranty has expired.
The other issue is the clicking/ticking of the compressor when I have the defroster or A/C on.
It's clicking on and off everyth 15 or 20 seconds. It's so loud and I can actually feel it jerk the brake pedal when I have my foot on it.
I'll be sitting in traffic at a red light and everybody's looking at my car wondering what the hell is that clicking noise coming from my car.
The dealer tells me "Oh that's normal".
Well, I've never had a car, Ford or otherwise, make such a loud noise.
I'd really appreciate insights on these issues.
Thanks.
Thanks.
I'd say check your lugnuts and if OK, head to nearest dealer. shouldnt be any noise there- somethings loose that shouldnt be.
Clacking? Mine does a similar thing when I put it from Park to reverse(sometimes does it when I go from Park to Drive), while my foot is on the break there is a grinding sound that comes from the rear of the car. Took it to the dealer and when I tried to reproduce the problem it would not do it. Anyone got any ideas?
Just was looking through the TSB's Jack does your problem sound at all like TSB 04-24-20? You might want to check that one.
Thanks.
I had a similar issue with my car until they changed all the park brake cables because they were getting frozen (litterally) and wouldn't disengage. I don't know if the parts are revised or anything but no more noise.
Strange. I'm taking my car in tomorrow for the exact 2 things you've posted here. Clicking noise with A/C on (or heat), and clacking noise when applying the breaks.
One other thing I've noticed though, is that I'll also hear an even more distinct thumping sound if I apply the breaks, then turn the steering wheel to the right.
Whenever I'm backing my car into or out of my driveway, the clacking noise resonates between my house and my neighbours house...this actually amplifies the noise such that my neighbour came out of his house to enquire what the hell the noise was the other day.
It's embarrassing
I'll be taking my car back to the dealership for this issue again...and this time I won't take it back till they fix it.
Just got the car back (dealer had to keep it overnight to get the parts). Turns out the clacking noise from the breaks was my front rotors. They were "burnt" (as it was described to me). Basically, there were holes developing in the front 2 rotors, so everytime I applied the break while the wheels were still turning, the break pads would hit these holes, making a clacking noise every rotation. Makes sense I guess. That certainly would explain it. And I didn't notice the noise on my drive home.
Now (obviously) I asked why this would happen to a car that's only 10 months old. They couldn't give me a real answer. All I got was the typical "It happens from time to time" nonsense. So I asked if this issue was typical of this make/model car. They said no. I guess I have to take their word for it ....
As far as the A/C noise. I guess that's normal. At least that's what I've been told. We'll see if any issue arise from the noise or not.
Holes in the front rotors?! What the heck is that about? Are these holes you can see? If I go out to my car would it be possible to see these holes?
BTW, what did they do to fix the problem?
Thanks for informing us!
What they did tell me was, they replaced both front rotors to fix the issue.
Maybe I missed this but is yours automatic or manual? I was just with a buddy last night that has an automatic and when he put his in drive or reverse, it clanked really loud. Sounded to me like a driveshaft or differential as well. He also said that the dealer said it was ok which I really find hard to believe. If it didn't make the noise when you took it home, than it isn't ok when it does.
Rando
8/25/21 11:12 AM
