check engine light...
Old Mar 10, 2007 | 02:44 PM
loserpunk603's Avatar
driving home from work i noticed my check engine light on last night... i guess i have to bring it into to get checked... any ideas what it might be?
Old Mar 10, 2007 | 02:56 PM
G.T's Avatar
G.T
no way to tell unless you have any noticable symptoms, a warning message or an OBD Scanner/handheld tuner to pick up the DTC trouble code
Old Mar 10, 2007 | 03:05 PM
neil07gt's Avatar
If you have the IUP and message center, try this (it works on my 07):
(1) with key in ignition and car off, hold down both the RESET and SETUP buttons
(2) turn the key to ON (two clicks)
(3) release the RESET and SETUP buttons
(4) Look and the message info center, and press the RESET button to cycle through the display options, eventually you'll ge to the option for DTC
(5) See if it mesage center will list the DTC trouble code
(6) to exit, turn the key to OFF
Old Mar 10, 2007 | 03:14 PM
G.T's Avatar
G.T
*runs outside to try this on his 06*
edit: sweet! it works
live and learn.. thanks Neil
Old Mar 10, 2007 | 09:22 PM
all it says is dtc continuous code none
Old Mar 11, 2007 | 12:20 AM
G.T's Avatar
G.T
i suppose your CEL is not on anymore is it?
Old Mar 11, 2007 | 10:31 AM
DoctorQ's Avatar
Did you recently install/ re-install a CAI ?
Old Mar 11, 2007 | 11:27 AM
nope no mods thusfar and yes it's still on i'm probaly gonan bring it by ford monday and have them look at it
Old Mar 11, 2007 | 12:00 PM
DoctorQ's Avatar
good call... if it's stock, let the warranty take care of it.
Old Mar 11, 2007 | 01:00 PM
do you know if warrenty covers the lever that adjusts seats too? my friend broke the one on the back of the passenger seat
Old Mar 11, 2007 | 01:08 PM
G.T's Avatar
G.T
i think they'll categorize that as misuse, or regular wear and tear..
however both mine broke although i've only had passengers in the rear seat maybe 4 times.
plenty of people here reported them breaking too.. they're just not designed properly!
Old Mar 12, 2007 | 10:42 AM
that sucks.... i'll ask anyway
Old Mar 12, 2007 | 10:40 PM
so i went to advace and it was the gas cap not on tight enough
Evil_Capri
Sep 11, 2015 08:39 AM
oldnjguy
Sep 10, 2015 02:39 PM
