Changing the tps on 4.0
Old Dec 22, 2011 | 02:16 PM
Reverenjim's Avatar
Anyone know the reason ford tells you to heat the throttle body before changing the tps. Is this necessary? Would taking the car for a ride first warm it up enough as they said heat it to 130 degrees
Old Dec 23, 2011 | 07:35 AM
amustangrocks's Avatar
i`m thinking its just because there is lok tite on the 2 small torx bolts, and they can break removing them. they can be a real wrist breaker by the time you get them out. a little heat will help them come out easier. course, thats just my guess
Old Dec 23, 2011 | 10:05 AM
Reverenjim's Avatar
That does make sense. I saw the lock tite on the new screws. Ford is the only one that says you will need heat. I was thinking of maybe just taking it for a ride to get the engine hot as they said 130 degrees which isn't much
Old Dec 23, 2011 | 03:32 PM
Reverenjim's Avatar
Changed the tps and running good now. The heat is definitely for the lock tite on the screws as they were a PITA ?
Old Dec 24, 2011 | 07:28 AM
KdF's Avatar
KdF
Yep. They tell you to have it a little warm for changing the plugs too. Gotta love aluminum and puter chit.
Old Dec 24, 2011 | 07:24 PM
Reverenjim's Avatar
I hear ya. The heads snapped off even with the heat. Had to use heat and vice grips to back them out. Thought about saying the hell with it and going to get the BBK throttle body but I don't think it will pass emissions.
Old Dec 27, 2011 | 09:50 AM
the bbk can be hard to deal with. wow, broke those bolts off. a heat gun would work to warm them up, but have to be carefull with all the plastic stuff. glad your running good again. that sensor can really reek havoc
Autotooner
Nov 24, 2017 12:42 PM
CiniZter
25
Apr 28, 2016 05:41 PM
ricky1728
Feb 11, 2016 07:25 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
