Car seems to be choking on fuel?
Old Nov 16, 2008 | 03:04 PM
classix_stang289's Avatar
I've been having a problem with my car ever sincer i installed my obx long tube headers and racer cai. I go to start the car it runs fine for almost two minutes then it will run rough and a strong gas smell is noticable but then clears up after about a minute and runs fine. It happens everytime the vehicle sits for awhile and then i go to start it up then it happens and then it clears up.
what could make the car choke on gas? I know that the O2 sensors are further back, but i got new sensors in there and tuning from brenspeed for all my mods. My performance mods are OBX LT headers, C&L racer cai, udp,delete plates,4.10 gears, 93oct racer tune from brenspeed.
i dont think it would be a tuning issue cause i've recieved numerous tunes from brenspeed although people have mentioned to me about altitude affecting the vehicle? Maybe tuning for my altitude i live in(NJ)?.
How about fuel injectors leaking into the cylinders? Fuel pump? what makes a car choke on fuel?
The car is trying to pull fuel away but it cant and it only trips a sensor stuck rich code but theres nothing wrong with my sensors, its a false code. theres something thats causing the sensor get stuck rich.
Please help me
Old Nov 17, 2008 | 04:19 PM
RRRoamer's Avatar
It might be going closed loop on cold O2 sensors that are not sending out the right signal until they can warm up more. I would THINK that you would get some kind of code eventually if that was case (slow O2 response would be my guess), but who knows.
Old Nov 24, 2008 | 05:50 PM
i got the slow response code once, most likely due to the LT headers with sensor positioning.
what about something with the fuel system? leaking injectors? pump problem?
i do notice a new sympton so to say which is inaccurate fuel gauge, i dont think its my cluster cause this started happening with my rough running problem.
Ecostang
Nov 3, 2022 08:50 PM
Detroit Steel
Ecoboost
19
Jul 17, 2016 05:54 PM
JonathonK
GT350
38
Apr 28, 2016 08:11 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
