Battery Discconect
Old Apr 27, 2006 | 09:19 PM
gabeh1018's Avatar
Could anyone provide me with detailed instructions on how to remove the left(red) battery terminal.. specifically (for lack of a better term) thinger with the nut on top???? it appears to be some type of lock mechanism.. i really dont know what it is.. but i dont know how to remove it.. cause there is a nut on the bottom that i cant get to.... yea i might be retarded but.. help
Old Apr 27, 2006 | 09:40 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Get an open ended wrench, 10mm I think. Take the wrench, place the open end over the first nut. Turn the wrench counter clockwise and repeat until the bolt loosens. You'll also need a 5/16 socket. Place the socket on the 'other' nut and turn counter clockwise as well until it loosens. Then get a flat head screwdriver. Place the screwdriver under the clamp and gently pry upward. Remove the clamp and secure away from the battery so that it doesn't spark. Hope that helps.
Old Apr 27, 2006 | 09:42 PM
gabeh1018's Avatar
oh ok... so basically that nut on top lossens the clamp... so you can pry the clamp thats around the battery terminal off??/
Old Apr 27, 2006 | 09:58 PM
I lust for a M24
Read the post again. I added something. You'll need to remove the first nut (closest to the fender), then loosen the other with a socket.
And be careful not to let any of your metal tools touch any metal on the car while you're wrenching on that positive terminal... that could be bad. [img]style_emoticons/<#EMO_DIR#>/eek.gif[/img]
Old Apr 27, 2006 | 10:05 PM
gabeh1018's Avatar
thanks a lot.. appreciate the help
Old Apr 27, 2006 | 10:18 PM
I lust for a M24
Good luck with your stereo install. FYI - your next post will be "Where do I run my primary wire?"
Answer - take off your right front tire (under the battery), remove the rear section of the fender liner (4 or so plastic screws that you'll need to loosen then pop out), and you'll see a rubber grommet that you can poke through that leads into your passenger kick panel. From there you can remove the plastic trim and run it back to your trunk.
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
PonyMuscletang13
Sep 24, 2015 01:40 PM
