2007 Mustang V6 Intermittent starting
Old Jul 18, 2024 | 10:16 PM
Dirp's Avatar
2007 Mustang V6
220,000 miles
Automatic
​​​​​​What's up guys. Hoping to get some help with an intermittent no crank. issue. The car cranks fine early in the day and then won't crank when motor is warm. I had this issue before so I put in a brand new starter from advanced auto and it's still doing it. I'm able to start it with a wire bypassing the relay at the fuze box under the hood.
I did a multi meter on every fuze box and plug in as well as the connections for the starter and all connections are good even if the car won't start at the key for that moment.
Could that fuze box be the issue? I've seen multiple threads on that and just looking for some suggestions and things I should investigate since I'm sure I'm not the only one here to have that issue. Maybe also the fuze box inside the passenger panel?
Anyways, any guidance from personal experience would be much appreciated. Thanks
Old Jul 18, 2024 | 10:26 PM
05stangkc's Avatar
Welcome,
Since You Replaced The Starter I Assume You are Having a CRANKING Problem vs a Starting Problem Which Means Engine Cranks / Turns Over But Does Not Fire. Anyhoo Just to Be Clear. Also You Did Not say if it Was a Standard or Automatic Which Can Help as Could Be Issue at Clutch Interlock Switch vs Neutral Safety Switch.
Kc
Old Jul 18, 2024 | 10:30 PM
Dirp's Avatar
Welcome,
Kc
I'll update now. Sorry long day. I should've added those details
Engine does not crank. It will crank bypassing the relay with a wire. Automatic. Car will not start in neutral either since I know that's a symptom on neutral safeties in automatics
Old Jul 18, 2024 | 10:33 PM
05stangkc's Avatar
Here is The Wiring Diagrams!
First Thing I Would Do is Check The SJB For Any Water Intrusion!
If You Are Not Familiar With the Issue See This Thread! If You Find Any Cruddy Connections Clean Them With Contact Cleaner & Follow Up With TSB Thread To Remedy!
https://themustangsource.com/forums/...26-7-a-550617/
Pdf Shows Connector & Location!
Well It has Been a Long Day For Me as Well Hopefully This Will Give You Some Ammo To Work With!
Also Added Starting System Diag. Pdf.!
KC
File Type: pdf
File Type: pdf
Old Jul 18, 2024 | 10:49 PM
Dirp's Avatar
Thank you. I'm going to check that out tomorrow if the storm holds off otherwise it'll be the weekend and I'll post back. I don't have wheel wells because of being lowered so that would make sense.
If you have any advice on OD off light flashing, I'm all ears. Haha. Shifts good, just replaced the solenoid pack and there are zero codes now, but OD off light flashing. It used to turn itself off, but now it's flashing all the time. I replaced the speed sensor as well that's towards the rear of transmission, so my next course of action is to try the speed sensor above the neutral safety more towards the front of transmission.
But any other advice will be heavily considered. Haha. Fresh transmission oil change and it is at the perfect level.
Sorry in advance. Haha.
Old Jul 18, 2024 | 10:58 PM
05stangkc's Avatar
The O/D Light Issue Should Throw a Trouble Code! Need a Good Code Reader These Days That Pulls DTC's and Body Codes!
KC
Old Jul 18, 2024 | 11:16 PM
Dirp's Avatar
KC
Good info. Thank you very much for leading me in the right direction and reassuring I'm looking in the right direction. I'll see what the local auto parts store use for code readers since mine is a cheap one. Thank you again. I'll post back here with updates.
Old Jul 19, 2024 | 12:18 AM
05stangkc's Avatar
Your Are Welcome!
Hopefully a Solution Will Come Quickly!
KC
Old Jul 20, 2024 | 08:23 AM
Dirp's Avatar
Your Are Welcome!
KC
Hey. I think I figured out the cranking issue. I had to bend a key ring to bypass relay on fuze box so I think that insert/tab things for the relay got bent out so contact is poor. I slightly bent one of the relay prongs to see if the connection would be better and yes it was. This will work for a while hopefully, but will get a new fuze box near future.
Will post back here on the OD off flashing issue once I mess with that some. Will get it scanned with a good scanner and or try replacing that front speed sensor above the neutral safety.
Old Jul 20, 2024 | 08:30 AM
05stangkc's Avatar
One Day One Step at a Time! You Will get it Figured!
Kc
Old Jul 20, 2024 | 08:47 AM
Dirp's Avatar
Kc
Thank yer!!
codad1
Feb 24, 2022 03:42 PM
Jose Covarrubias
Jan 10, 2021 03:00 PM
CHolowenko
Oct 27, 2018 12:16 AM
thebestembee
Jan 21, 2018 12:18 AM
blackonblack2007
Oct 21, 2014 09:27 PM
