05stangkc
close
- Join DateNovember 27, 2004
- LocationVisalia Ca.
Liked:4,345 Times in 3,242 Posts
@Lynp
PM Me Your Vin.
With Exact Part Number and ID# on Actual Part Itis Easier To Get Correct Replacement. Ford Part Numbers Are Different Than Number on Sticker on Part. Having Both is a Good Idea. I Can Pull That From Vin.
You Are Simply Trying to Replace a Damaged Harness Correct. Not Some Kind of Swap or Change To Vehicle?? Back Story Maybe Helpful.
I Have Been Known To Find a Part or Two!
KC
For Used Parts as an FYI.
The Big Difference in the 05 Gt Headlight Harness is With or With Out The Perimeter Alarm!
I Can Try a National FORD DEALER Parts Locate to See if Any are Still on a Dealers Shelf Somewhere if you Have Not Had That Done???
Have You Tried Any of The Large Mustang Auto Wreckers??
https://prestigemustang.com/
http://ranchomustangparts.com/
Colorado Mustang Has an Issue With Website But Here is Their Number. 303-343-7024
Lkq Parts is Connected To A Ton of Wrecking Yards. You Would Need To Call!
https://www.lkqonline.com/
PM Me Your Vin.
KC
