Time to rebuild an engine...
Old Mar 30, 2007 | 08:04 PM
Puter's Avatar
Okay, the 93 is tired. I think driving 60 miles with no oil pressure may have helped that. It still runs good. But the bottom end is shot. Driving 60 miles with no oil pressure did not help. I can tell the bearings are gone.
So, I need to find a decent machine shop.
All I want is basic machine work.
Hot tank and check the block, bore if needed, galley plugs, freeze plugs, cam bearings, finish hone, check and turn the crank if needed, polish it, and check the rod big ends.
The ported E7 heads are still good. May try to see if someone wants them for $100. My Edelbrock Performer may even bring ~$50.
I plan on keeping the stock 93 cam, seeing if I can trade my 1.6 roller rockers for 1.72 ones, find some GT40 heads, then throw on a Weiand Stealth intake and the 600 Holley I have and stay with the Hooker SuperComps I got.
I figure I can find used GT40 heads for ~$300. Rebuild kit for $300. Intake for $150. Machine work should be $300. Nice little budget build. Still a nice everyday driver that gets decent gas mileage. Then I will have to work on traction considering I have none in first and second is somewhat gone now.
Opinions?
Old Mar 30, 2007 | 08:34 PM
Redbaron93's Avatar
Hey Ralph, what would you want for the 1.6 rockers?
Old Apr 2, 2007 | 07:32 AM
LMan's Avatar
Ive used General Automotive in the past with good results (block prep), I don't know if they are still in business. You may want to up your block/crank/rod prep budget by a hundred dollars, though.
Old Apr 2, 2007 | 01:59 PM
Puter's Avatar
Nope, they are not in business. I also used them with good luck. That is what it cost me two years ago by them.
Hmmm... I want a set of 1.72 rockers for the 1.6 ones. *grins*
Skip, I will keep you in mind when I get to that point.
Old Apr 3, 2007 | 08:26 PM
65stangman's Avatar
Have you called Southern Cylinder Heads, they run a Ford 302 with clevland heads on thier drag car. definately Ford guys. They do diesel heads for me and are fair priced.
Old Apr 4, 2007 | 06:50 AM
Puter's Avatar
I used SCH back about 7 years ago. They were under some other management. When I tried them again 6 years ago when I was helping to rebuild a 67, they did great. Then they went downhill under new management.
This is the second time someone mentioned them, though. Perhaps they have turned around.
Old Apr 4, 2007 | 09:47 AM
Mberglo's Avatar
They helped me fix a 289 head I dropped and broke. Worked out and was reasonably priced.
Old Apr 4, 2007 | 09:58 AM
65stangman's Avatar
Southern Cyl Heads
256-535-4403
Ask for Shawn or Steve
IF you are interested
Old Apr 4, 2007 | 10:11 AM
kennyg's Avatar
Roland Machine and Exhaust
I've used Roland Machine and Exhaust here in Hazel Green for both machine work and exhaust. Most recently I had them surface a 200 6 cylinder manifold and they did a great job, charged me $25 labor. I know he's also built quite a few stroker engines. Give Kenny Roland a call at 829-9050.
Old Apr 5, 2007 | 09:55 AM
LMan's Avatar
I had a bad exp with SCH about that same time (6-7 yrs ago), so I have avoided them since. They could certainly have changed for the better in that time, however.
jc46002003
Apr 15, 2016 03:00 PM
bigaaron
Jul 29, 2015 07:19 AM
chadh92
Jul 29, 2015 06:56 AM
Antciall
Jul 23, 2015 02:04 PM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
