Motive brake pressure bleeder?
Old Sep 10, 2011 | 08:45 PM
Puter's Avatar
Anyone have a 0105 (hopefully with the 1105 adapter) that I can borrow? Or some other type of pressure brake bleeder system?
Old Sep 12, 2011 | 07:35 AM
Mberglo's Avatar
Why do you need a pressure bleeder? I've bled a whole bunch of systems and never needed anything more than this:
http://www.harborfreight.com/one-man...:referralID=NA
Old Sep 12, 2011 | 09:20 AM
Puter's Avatar
I've got two of those and tried it out Saturday. I evidently have trapped air somewhere that this thing is not getting out. Either that, or I need to borrow someone's leg. I tried doing it myself.
P.S. Replaced power booster and master cylinder. Shoes, pads, drums, rotors are all good. Back brakes are adjusted properly.
Problem: Pedal is going near to the floor.
Old Sep 12, 2011 | 11:53 AM
Mberglo's Avatar
sounds like the master needs to be bled. I had that happen not long ago. Crack all bleeders open and put a coffee can under each one. Let it gravity bleed for an hour or so and try to bleed them again. Worked for me.
Make sure you have a little brake fluid in the bleeder before you start pumping the pedal.
Old Sep 12, 2011 | 11:56 AM
Mberglo's Avatar
Re-read your post. When you say pedal goes near to the floor, does it have pressure near the floor? Do you need to adjust/replace your master cylinder rod? Did you install the same style MC that you removed?
If the pedal is near the floor but hard, I would look for rod length issues.
Old Sep 13, 2011 | 07:04 AM
Puter's Avatar
Bench-bled the MC. Replaced with same. In fact, replacing the booster and the MC made no difference. Bleeding made a very small difference.
It's not hard. It's just low and a bit soft. (I hear you laughing)
I am thinking there is air trapped somewhere that is not bleeding. In researching on Corral, possible it is back in the junction since the rear was replaced at some time.
I like your idea about opening all of the bleeders. May try that. Thanks!
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
