Fuel or ignition?
Old May 22, 2008 | 04:58 PM
Puter's Avatar
Fuel or ignition?
I'm leaning towards fuel.
I filled up a couple of nights ago at Chevron. 93 octane as usual.
Afterwards when I have the throttle halfway to the floor-to-WOT, it stumbles. And it seems to be getting a little worse now. I changed out my fuel filter, no help. As you know, I'm carb'ed.
I will be troubleshooting this weekend (tomorrow), but is there anything else I should be looking at? The Chevron gas now has Ethanol in it. Since this is half-throttle to WOT, could the Power Valve circuit be having an issue? Stumbling seems to me like the jets are getting uncovered, but...
Old May 22, 2008 | 08:25 PM
mmr007's Avatar
did you check the flux capacitor?
Old May 22, 2008 | 10:59 PM
usmcrebel's Avatar
ralph, im still having this problem with my 67, i had the problem with my last carb too, i've changed the filter and everything, and i didnt even think about the jets on this carb...that would be the first place i start out at.
Old May 23, 2008 | 06:37 AM
NOStang05's Avatar
hey dude,
could be a bad fuel injector. my buddy's car was doing that.
Old May 23, 2008 | 07:54 AM
Bigred15's Avatar
Originally Posted by NOStang05
hey dude,
Please tell me you did not just say that!!! Last time I checked, carbed cars do not have fuel injectors.
On to Ralph, what about you fuel pump? How long ago did you replace it?
Old May 23, 2008 | 08:19 AM
NOStang05's Avatar
hey dudes,
my bad didnt see that aprt
Old May 23, 2008 | 02:46 PM
kennyg's Avatar
Put in a bottle of fuel treatment. Might be a $1 cure, not bad preventive maintenance either. kennyg
Old May 23, 2008 | 05:04 PM
mustang6804's Avatar
that sounds like a good idea, my friend did the same thing with his carb'd 86 and it did the trick, I think it was a similar problem
Old May 23, 2008 | 05:19 PM
BA Mustang's Avatar
Originally Posted by kennyg
fuel treatment
Depending on how old your carb is, you could use some carb/fuel injector cleaner.
Old May 24, 2008 | 06:14 AM
Puter's Avatar
Dangit. Yes, I forgot to put in the banana peel and beer (with can) into the flux capacitor.
I use Techron a lot. So it has had cleaner run through it all the time. I was getting 20MPG combined with this thing so I figure it may be running lean. I filled up with different gas (8 gallons) and it is still there. I adjusted the float levels and replaced the cap/rotor (they looked like they needed replacing so I thought maybe the carbon tracking may have had it jumping fire, but). Yeah, I am wondering about the fuel pump. I did it about 3 years ago, though. I really need to throw a guage on the line to determine if I am getting 7PSI or not.
I have gone ahead and bought a Holley Trickit and will pull off the front bowl. Take the metering block and clean and spray out with compressed air and replace the PV. Then go from there.
Thanks, guys.
Old May 25, 2008 | 04:32 PM
Puter's Avatar
Well, there was not much trash in the carb, although I did not like how the gaskets looked. Regardless, I cleaned up the metering block, blew out all of the passages, replaced the power valve and several gaskets. Since I had replaced the cap and rotor, I decided to check the plugs. Found #5 was caked. Threw in a new set and now my surge is gone.
WooHoo!!!
And my M609 certification came in the mail yesterday. I'm gonna put this puppy back to R12.
Old May 26, 2008 | 10:38 AM
Mberglo's Avatar
Certification? Pfft.
Funny thing is that everyone stockpiled the R12, and then traded in. There's tons of the stuff sitting on people's garage shelves. Still better make sure your system is tight before filling.
Old May 27, 2008 | 07:04 PM
Puter's Avatar
I went ahead and bought 6 cans of National. The system is leak-free (all new parts except for condenser and compressor), except for the low-side aluminum quick disconnect. Piece of junk. Plus, I can get the system working really well, but it is still not the same. A friend allowed me to borrow his R12 gauges.
The core temp gets down to 44 while driving (ambient was 88).
But I want stiff nipples.
Old May 28, 2008 | 08:08 AM
usmcrebel's Avatar
as long as the stiff nips never make it on to this webpage i say go for it see if you can make snow from your AC
Old May 28, 2008 | 08:17 AM
NOStang05's Avatar
Hey dude,
no won wants to see your nipples.
Old May 28, 2008 | 09:35 AM
Puter's Avatar
Dangit, what about no loss?
And Asa, you must have missed the pics when I swapped the engine. I can post them again. *grins*
Old May 28, 2008 | 11:23 AM
usmcrebel's Avatar
lol ralph, i didn't miss those i just didn't want the memory to seer the remainder of my imagination
NC14GT
Feb 20, 2023 09:42 AM
Fastnloud
Feb 15, 2016 05:21 PM
Sep 16, 2015 06:44 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
