does anyone local use the diablosport?
Old Jun 29, 2007 | 03:29 PM
virginiavenom's Avatar
might need a little tutoring......
questions I have are:
1. when I turn off the traction control in the tune, is it off whether the light is on or not (ie if I push the button will it turn on traction control, or is it off no matter what)
2. since I have a catless mid, I disabled bank 1 and 2 of the down (heaters) if I remember right, that's what I needed to do right?
3. I've heard the "lean" and "rich" markings on the diablo's are wrong.....or was that the numbers
4. should I go ahead and data log this thing or no?
sorry I just want to make sure I have those things right....I already fixed my gear ratio problem.
Old Jun 29, 2007 | 04:15 PM
workmangc's Avatar
Read your users manual.....page 5 covers the fuel thing.
http://www.diablosport.com/downloads...7142_U7158.pdf
Old Jun 29, 2007 | 04:18 PM
durrr....ya I found it after I posted......I didn't think they had one online......sorry, can a mod delete the post?
Old Jun 29, 2007 | 04:21 PM
Grabber Pony's Avatar
what exactly is the data logging?? Ive been meaning to try it out on my Xcal ...
Old Jun 29, 2007 | 05:07 PM
basically, it monitors parameters that go through the ECU, via sensors on the vehicle, it collects all the data to the X cal during normal and WOT driving, it greatly assists when getting custom tunes.....I personally only helped someone start it on an xcal 2 in germany, but I just read it out of a book....basically then you get the information from the xcal and send it on to your tuner.
Old Jun 29, 2007 | 09:33 PM
96TennGT's Avatar
With the Xcal II it's pretty easy if you have a laptop. I always have problems trying to just log to the Xcal but if I use it to send the data to my laptop it works everytime. If you want I can show you how the data log thing works.
Old Jun 29, 2007 | 10:39 PM
intresting..since i finally found the cable to mine i'll have to check it out.
Old Jun 30, 2007 | 03:35 PM
workmangc's Avatar
I've attempted to data log with my predator, but once I unplug the predator after the session is over I loose my data that was on the computer.
Also looking at my fuel trims, one bank is -12 on long term and the other is -4.....any idea on the difference???
09-gt/cs
Oct 15, 2015 10:03 AM
GLOCKer
Sep 28, 2015 05:20 PM
50Cal
Sep 16, 2015 03:54 PM
