Battery Cover
Battery Cover
Just finished making a battery cover for the mustang. Going to try to keep the water off of it. Made it from finishing plywood, will put fiberglass resin on it, and then paint it black.
I made the top a little small, and The place where the cables go through are bigger than the cables so that some air can get through. If that isn't enough I could make some vents on the side of it.
Why dont you relocate it to the trunk and put it in a marine battery box. Not only will it clean up the engine compartment and keep the battery away from the elements, but will tranfer the weight to the rearend to give you better traction. kennyg
http://store.summitracing.com/partde...5&autoview=sku
I plan on doing the relocation kit later. I'll do that when I turbo the mustang. Moving the battery will allow for the piping to go through there and to the intercooler.
PonyMuscletang13
9/29/15 09:40 AM
