Wrong Gear
Wrong Gear
This is my story
I was coming off a clover leaf and merging onto the freeway. I was in second gear thinking "Ok let see what my Bullitt can do". I nailed the throttle to the floor and I took off like a bullitt. I then shifted into 3rd, and I was having problems getting it in! I think that my clutch wasn't alway in ? So after I figured out that I messed up the fun ,I would just abort the idea of raising a little hell. I went to put the tranny into 4th. That is when the mistake happen, instead of putting into 4th I put it back into 2nd! The tires lockup for a split second on the freeway!
I am sure everyone on the freeway was saying " Hay look at the dumb *** trying to destroy his Stang"
I am sure that my valve train took a hit. The car is just fine, But I am feeling bad for the Stang
The tires didn't actually lock, they were just going a lot slower than the car wanted them to.
The valve train probably didn't take a hit, the tires did.
If you had enormous tires and they just dug in, you might hurt the drivetrain.
The engine should be able to maintain the rpms from rising too much as long as the tires give.
Feel bad for the tires.
This is my story
My question is why am I getting 100% locked out of 3rd gear when the RPM's are (roughly) above 4500? This has happened to me twice; one more time and I'm going to buckle and take it to the dealer
>>I nailed the throttle to the floor and I took off like a bullitt. I then shifted into 3rd, and I was having problems getting it in! I think that my clutch wasn't alway in ? <<
Try this method of shifting to third from second: grasp the shifter ball underneath using the palm of your hand and move it toward third without much thrust. Mine goes in smooth as silk. If I grasp from above and forcibly move towards 3rd, it will sometimes not want to cooperate. Hope this helps. I have also noticed that it shifts easier as the miles increase too.
The T3650 Trans has suffered form trouble with 2-3 shift form the beginning the S197 remote shifter has only made it worse. A MGW shifter will help. There is also a support bracket that can be added to cut down on the body Trans misalignment that will also help.
FYI this gets worse the colder the Trans is.
You didn't hurt the thing. I can tell you that I tried something crazy and it didn't hurt anything, so you weren't even close. I took of T/C and dropped it into 2nd at 62MPH.
What you thought was bad, I thought was awesome! I was next to this Ferrari and I went for it. The tires barked, then burned, then I hit about 68 and had to shift to 3rd.
Dude in the Ferrari was like WTF! Here's some idiot in a stang doing burnouts on the highway at 60 MPH.
Not going to do it again, but after about 15K more miles on the ODO nothing seems out of the ordinary.
Rule of thumb is T/C won't let you do anything really stupid. So you didn't hurt anything.
You didn't hurt the thing. I can tell you that I tried something crazy and it didn't hurt anything, so you weren't even close. I took of T/C and dropped it into 2nd at 62MPH. What you thought was bad, I thought was awesome! I was next to this Ferrari and I went for it. The tires barked, then burned, then I hit about 68 and had to shift to 3rd.
I can't say I'll be doing it in the Bullitt anytime soon though!
As long as you don't overspeed the engine, you're fine. My old 01 with a hd spec clutch, I used to downshift into 2nd and do it on purpose for kicks when I came into work and the guys were out smoking on the side of the building...As was mentioned, you would probably need bigger tires with more grip then the stockers to hurt it unless you were really going fast, most of the time at those engine speeds the trans would let you do it in the first place. As for missing shifts, most of the time its your foot not being in sync with your hand and you just goof it.
try double clutching it. That does make a difference.
It's goofy reading this thread. All you guys, and many others have problems shifting in to 3rd.
I have NO problem shifting into 3rd, but **** even w/ the MGW shifter I get locked out of 2nd. What gives? It's like I have the exact same problem getting into 2nd as everyone else has getting into 3rd. It sucks even worse not being able to drop back to the #2 gear.
