Bullitt suspension
Old Mar 16, 2008 | 05:31 AM
1 COBRA's Avatar
Originally Posted by RCSignals
IRS but you knew that?
I'd guess I did at one time, old age must be sneaking up on me. Thanks for the refresher.
Old Mar 16, 2008 | 09:47 AM
Whammer's Avatar
I thought I had read that it had the same panhard bar from the GT500.
Old Mar 16, 2008 | 06:12 PM
RCSignals's Avatar
What's it matter in the scheme of things?
Do you have a delivery date yet?
Old Mar 16, 2008 | 06:14 PM
RCSignals's Avatar
Possible. It has the rear axle assembly from the GT500KR.
also is supposed to have the front suspension arm brace from the GT500, which is just a FRPP piece I think.
Old Mar 17, 2008 | 12:33 PM
StangNut's Avatar
Originally Posted by Jmono
Then it would need a shorter panhard bar at the least or else the axle would be shifted off center. <O</O
Since the rear is already off center so much from the factory on a stock GT, I doubt they were worried about what a 1/4" drop would do.
Old Mar 18, 2008 | 06:29 AM
Tony Alonso's Avatar
Why do you say it is off-center with the stock suspension set-up?
Old Mar 18, 2008 | 06:49 AM
StangNut's Avatar
They were all off center when the '05's first came out. Most people didn't notice it because the back end is jacked up so high it's not as obvious, since the tire isn't close to the wheel well. Once people lowered their cars and the tire was closer to the wheel well, it became very obvious. That's why there used to be tons of discussion about the rear end shiffting "when the car was lowered" (I noticed mine once I put on wider wheels & tires) I checked it before I lowered it, as well as many other people, and we all got the same the thing... off-center from the factory.
Old Mar 18, 2008 | 10:42 AM
Do you have some measurements you could share from your vehicle? Thanks!
Old Mar 18, 2008 | 11:19 AM
StangNut's Avatar
It was off center to the LEFT 1/2" from the factory. Lowering the rear of the car moved it 1/4" to the RIGHT, actually improving the factory setting.
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
samjluck
Sep 17, 2015 10:24 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Gabe
Sep 7, 2015 03:30 PM
