Bullitt suspension
Old Mar 10, 2008 | 11:44 AM
Jmono's Avatar
Bullitt suspension
So the Bullitt rides a bit lower than the GT. Did Ford design new LCA's and panhard bar to account for the change? How do they adjust for the change in pinion angle?
Old Mar 10, 2008 | 04:19 PM
RCSignals's Avatar
it's only about 1/4" lower in the rear
Old Mar 10, 2008 | 04:41 PM
goesfast's Avatar
New shocks, springs, dampers and stabilizer bar. Don't think Ford did anything with the front end outside of that. Oh yeah, don't forget the strut tower brace too.
Old Mar 11, 2008 | 07:45 AM
Jmono's Avatar
Then it would need a shorter panhard bar at the least or else the axle would be shifted off center. <O</O
Old Mar 13, 2008 | 06:17 PM
1 COBRA's Avatar
I'm wondering if stiffening the chassis with subframe connectors would be an improvement.
Old Mar 14, 2008 | 11:22 AM
goesfast's Avatar
Good point. It sure was with the 2001's, but perhaps there's a reason its void in the 2008's.
Old Mar 14, 2008 | 11:28 AM
WaltM's Avatar
So are these Bullitt specific? Or available from FRPP.
Old Mar 14, 2008 | 11:59 AM
Tony Alonso's Avatar
The drop was most likely within the design specs in such a way that a different panhard bar was not needed. I assume this was an engineering expense Ford did not want to incur.
Old Mar 14, 2008 | 12:10 PM
There are 2 "frame rail connectors" on the S197 chassis that essentially perform the same as subframe connectors. Many have questioned how effective a bolt-on connector was with the SN-95 car as compared to something welded in place. However, it was probably better than leaving it be.
Old Mar 14, 2008 | 01:01 PM
BuzzyStang05's Avatar
I've always theorized that the two piece drive shaft with CV joints on the back half accommodates different ride heights for the factory. But I don't know crap.
Old Mar 14, 2008 | 05:02 PM
RCSignals's Avatar
My understanding is the S197 chassis doesn't need them (coupe at least).
Perhaps in convertible form it does.
Old Mar 14, 2008 | 05:06 PM
RCSignals's Avatar
Supposedly Bullitt specific. I think though that the stabiliser bars are the Ford 'upsize' version which are the same as in the FRPP pack.
Some of what is on the Bullitt apparently will make it to FRPP
Old Mar 14, 2008 | 05:27 PM
goesfast's Avatar
I found that the 2001 Bullitt was the best handling Mustang I ever drove. It out-braked and out-handled my 2003 Cobra in my opinion, so perhaps the subframe connectors played a role here. Can't comment on the S197, as I haven't taken delivery yet (soon!!).
Old Mar 14, 2008 | 05:43 PM
1 COBRA's Avatar
I experienced the opposite with the '04 Cobra vs the '01 Bullitt which I had at the same time for approximately one year.
Old Mar 14, 2008 | 06:16 PM
RCSignals's Avatar
didn't the '03 Cobra come with sub frame connectors?
Old Mar 15, 2008 | 09:53 AM
goesfast's Avatar
Gee, I really don't know. Didn't keep it long enough, but I doubt it did. Perhaps George can comment.
Old Mar 15, 2008 | 10:28 AM
1 COBRA's Avatar
The coupe did not have them but I don't know if the verts had them or not. I would assume they did since my wife's '02 GT vert had them.
Old Mar 15, 2008 | 03:16 PM
RCSignals's Avatar
I can't find the reference now but I thought sub frame connectors was one of the things SVT added to the '03/'04 Cobra
Old Mar 15, 2008 | 03:53 PM
1 COBRA's Avatar
My memory appears to be failing me so your thoughts are probably correct. Did you find any reference as to the '03/'04 Cobras having IRS or did they have a solid axle?
Old Mar 15, 2008 | 06:50 PM
RCSignals's Avatar
IRS but you knew that?
I know many ended up changing to solid axle, at least the drag racers.
